Reusing pinion gear
explorer4x4
Anthony
Delaware
Base 2DR Eruption green
So let me start this out as I’m adding an air locker to my 2.3 manual base. I have a ford racing pinion and ring gear, rear end rebuild kit, arb locker and onboard air to install. I have 4.46 gears and intend to keep the same gearing so don’t try to convince me to regear.
I have 2500 miles only on my 23 Bronco as I travel for work and don’t drive a lot. Can I keep the original pinion in and simply use the new ring gear as the original is a welded gear open diff that I’m replacing?
I’ve never don’t this sort of job before. I have all the tools and the kit came with two crush sleeves, but why change it if it’s not needed? That’s half the work I’d save getting the gears to mesh properly. Trying to save some time and effort when they are still new parts? But I’m open to anyone who knows more than me here!
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
DO NOT do that! Better to swap you ORIGINAL ring gear to the ARB diff...that you can do!
Bmadda
Wisconsin USA
I think in this application the original ring gear is welded not bolted to the assembly. So best plan is likely installing the new matched set ring/pinion.
4.46 is welded? That sux, but ya, if welded then you are gonna have to do the whole job!
Joez60421
Illinois
Fleet of Toyota 4runners and Land Cruisers
Do not mismatch a used pinion with a new ring gear. You shouldn't mismatch them at all, but definitely not a set that's been broken in. Recipe for early failure.
Felix808
SRV CA
Yeah unfortunately everything I've read indicates the 4.46 ring gear is welded. Seems like only the 4.7 gear is bolted on.
So the 4.7 ring gear is confirmed to be bolted on?
explorer4x4
Anthony
Delaware
Thanks all, I thought I replied to this after the first couple of replies but it never posted. Looks like I’ll be using all the parts in my rebuild kit.
Including the second crush sleeve when I’m not happy with it the first time lol
kodiakisland
Arkansas
Open diffs are welded. Lockers are not. It's got nothing to do with the ratio.
Sozzy1269
Southern Idaho
23 Bronco 2door, 2012 Raptor, 2017 f350
I'm in the same boat as the OP. Got an ARB locker on the way and need the ring and pinion and install kit, as well as a compressor and manifold. Does anyone have a good source for these? Xtreme terrain has the gears in stock but is out of the install kit, but has a Nitro brand install kit. Is anyone aware of a cheaper place to purchase these, in stock? Thanks.
Tricky Mike
21 Bronco
You're almost certainly going to be removing the pinion multiple times when setting up the gears anyway. That's a big job to bite off with no experience. Do you have someone that's done gears that can assist?
This.
Felix808
SRV CA
mcinfantry
Lee
Louisiana
Badlands 2 door
This.
Man, ill give LESS than 10% success rate for OP
Im curious how or why you would have all the tools to set up a r&P but have never done it… i have the tools, but i bought them to do it and had help. This is not changing an air filer or sparkplugs…. Not in anyway saying it cant be done…. Just theres a reason most towns have gear shops….
Felix808
SRV CA
Yep, just because it goes together, does not mean it goes together correctly ;) Time / mileage will tell :unsure:
mygreenbronco
Keith
Washington
1973 Bronco
Set up several arbs. Just use the old crush sleeve to get the correct pinion depth then torque the new one for final install. The hardest part with the arb is to be very careful with the o rings when taking the carrier in and out any little scoring will cause air leaks and disengages locker. Btw other than a dial indicator for backlash and marking compound both can be bought at harbor freight for $30 there are no special tools.
Also don't let the people on here stop you. We all had start somewhere.
