Rear pinion angle for vibrations
CactassGrey
2023 Bronco Wildtrak
I'm getting some vibration from what I think is the driveshaft after a 3" lift.
My pinion is pointing down slightly in comparison to the driveshaft.
With this style CV shaft, should the pinion and the shaft be in line pointing directly at the transfer case?
I know with regular joint style driveshaft you want the transfer case and pinion to be at the same angle but I believe inreas somewhere the with CV style the pinion should point at the transfer case.
