So let me start this out as I’m adding an air locker to my 2.3 manual base. I have a ford racing pinion and ring gear, rear end rebuild kit, arb locker and onboard air to install. I have 4.46 gears and intend to keep the same gearing so don’t try to convince me to regear.
I have 2500 miles only on my 23 Bronco as I travel for work and don’t drive a lot. Can I keep the original pinion in and simply use the new ring gear as the original is a welded gear open diff that I’m replacing?
I’ve never don’t this sort of job before. I have all the tools and the kit came with two crush sleeves, but why change it if it’s not needed? That’s half the work I’d save getting the gears to mesh properly. Trying to save some time and effort when they are still new parts? But I’m open to anyone who knows more than me here!
