Redarc trailer brake controller discontinued
Wimpy
Tim
N.E. OHIO
2023 Ford Bronco
I just bought and received from that site last week.
mike8675309
Minnesota
Also my knee tends to hit the headlight switch when I'm getting in/out of the Bronco. I have no idea why, it drives me bonkers, because most of the time I don't notice that I accidentally turned the headlights on until my battery is nearly dead. But I can foresee myself bashing my kneecap into that knob.
I do hit it with my knee as well sometimes, but I always notice it because the dinger starts.
I did have a bad headlight switch that would randomly turn on my headlights, causing me to think I hit it when I didn't. The big key to seeing this is when I opened the door, the bell is running, but the headlight indicator isn't lit up, showing the mode it is in. When it does that, it's a headlight switch problem.
Squatchrocks
Squatchrocks
CO
Gave up on Ford and ordered the Redarc Tow Pro Trail for Ford Bronco from scamazon. Followed this guys install on youtube. Was hesitant at first drilling through lighting console but care with a step drill bit came out perfect. Definitely the better location. Note that the difference buying through Redarc than from Ford there is no foam or adhesive backing. I just used foam strip with adhesive backing and zip ties on inside of the plate under the steering wheel. And there's no black retainer clip for the main Ford connector so carefull pulling the old one out because you'll need to re-use it. See image with re-used clip attached.
Ford Bronco Redarc trailer brake controller discontinued Redarc Ford connector
Ford Bronco Redarc trailer brake controller discontinued Redarc-1
BDLNDZ
Pete
2024 Bronco
I ordered mine directly from Redarc. Saw no need to go thru Ford and maybe have any mark-up.
Rydfree
Benny
Alabama
I installed my RedArc Pro Trail a few months ago and put the knob in same location. Easy Peasy and haven't hit it with knee yet. Ordered the Ford combo kit directly from RedArc.
