Ford trailer brake controller unboxing
2Jeeps&PatriotX1
Denver, CO
@wilmerfjohnson it looks like the package for the bronco specific wiring harness states ETB-BRNC-T and the pic you posted of the harness removed from the packaging states ETB-BRNC-H.
@flip do you know if the plug n play harness within this kit from Ford can be sources using one of those 2 part numbers? I tried searching google but no luck.
2Jeeps&PatriotX1
Denver, CO
After contacting Redarc yesterday, they sent me the wiring pinout diagram for their $19.50 harness they believe should work for the Bronco. I compared it to the OP’s pictures he provided and I should be good to go.
Again, Im moving my redarc unit over to the Bronco w/ factory tow package so just needed the harness that connects the bronco to the redarc unit.
Scott1911
Oklahoma
2 Door BadSquatch
Please tell me that the Redarc part is the TPH-007.
2Jeeps&PatriotX1
Denver, CO
BRBlue
Houston
Toyota Tundra
@wilmerfjohnson Does the LED on your control knob stay on when a trailer is connected? From everything I have seen on the RedArc version it should, however on the Ford version it seems to only light up when you press the knob in. I’ve taken mine to the dealer and they are clueless. Just got a new unit and it behaves the same way. I have the factory tow package.
nkyhunter
mark
nky villa hills
2022 BRONCO,2021 JL RUBICON,2022F150 TREMOR
in step 7 of the install manual how in the hell do you unclip the phone charger plug and the one next to it. , i got the wires almost ran but i need to get these plugs out and don't want to break them, hate crap instructions. squeeze, pull apart what?
Grey Mare
Tim
I just installed the kit last weekend in the suggested spot. No need to unclip the phone charger and one next to it. And I didn't route the way they say to. I put the controller just below the Str. Column on the metal shelf, and ran the connectors from the switch straight along the drivers side in the console, much easier.
tjparisi
TJ
Buffalo
2021 Bronco Badlands 4D 7M
Does it light up when you press it without a trailer connected? Wondering if mine works, installed this for occasional use and don’t have a braked trailer at the ready.
BRBlue
Houston
Toyota Tundra
No. You have to have a trailer connected or use a test light in order for it to light up when pressed.
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
I just installed the controller yesterday and mine only lights up when pressed, yours still the same way?
BRBlue
Houston
Toyota Tundra
da_jokker
Jeep Wrangler JKUR
the "light" for some reason is the significant difference between the Ford version and the Vendor version.
if you look, even though the Ford mount and dial have a smaller hole off to the side, there is no actual LED in the switch itself...must have been a constraint :)
