rear wiper blade replacement
Valhalla
Valhalla
Chattanooga Tn
👀 Sketchy
Valhalla
Valhalla
Chattanooga Tn
Definitely. Ford of Blue Ridge, GA.
Oh shit! They are shady as hell. I went and looked at a 2004 superduty they had. Let's just say the engine had all the 6.0 warning signs.
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
Still not as bad as Shottenkirk Ford of Jasper. They took $4,500 of my father's money to fix a number of issues. He got it back and 5 minutes down the road had a bunch of CEL again. I pulled codes in FDRS and among them was a parts mismatch code. Meaning they didnt even install correct/matching parts to what they replaced. Unfortunately ya'll are in a loose-loose up there, unless you drive into Atlanta.
Valhalla
Valhalla
Chattanooga Tn
I'm in Chattanooga , Marshall Mize treats me decent.
BroncoChallenger
2024 Bronco
Maybe I missed something but the vid doesn't actually SHOW how it's removed, just tells you? Don't need to do it yet myself but it's something I'll need to do at some point.
gonyr
NY
Not really, but between the video and Ducati's explanation, I eventually got it. Hold the wiper arm with your left hand and the blade with your right. Pull the blade parallel to the window towards the passenger side. When it feels like it's not working and you're going to break something, pull harder. Eventually it will pop free and move about 1/4" to the right. Then it pretty much slides off easily towards the window.
Ducati1098
There’s really no good way to show it because the arm doesn’t move very far away from the glass.
Valhalla
Valhalla
Chattanooga Tn
Seemed simple to me:unsure:
sirron_cire
Sherwood, OR
2025 Ford Bronco Raptor
OK I know I'm going to feel stupid when somebody answers this, but how on Earth do you remove the rear wiper blade?
Mine is completely shot and has strands of rubber dangling. But I can't figure out how to remove it. I've tried pulling, pushing, twisting, sliding, looking for release tabs, and pretty much everything. I even watched a couple of youtube videos but nothing seems to help. It's like the darn thing is welded on there! This is embarrassing. I'm at the point where I actually spent a few minutes thinking it might be easier to replace the entire arm just to get a new blade on it. What do I do???
https://www.fordservicecontent.com/...ingEnabled=False&userMarket=usa&buildtype=web
https://www.ford.com/support/owner-manuals-details/bronco/2025/
Ford Bronco rear wiper blade replacement 1770608997583-fx
Blue Max
Craig
Texas!
2025 Bronco
I wish I could just take the whole arm off.....rear window wiper is something I would NEVER use....
tourproto
Portland, OR
2004 BMW 330i, 2022 Bronco BL 4DR
It’s off! But it took a ridiculous amount of force. Probably in the neighborhood of 75-80 pounds. Once it popped free the first time it became much easier to get the blade on and off.
Just found this thread and like you, it took a lot of force and nothing happened
I ended up using Ballistol, which is what I used to clean my guns and sprayed it all around the attachment clip. Waited a minute or so, gave it a tug and it popped right off.
just put a garage rag behind the blade, sprayed the area liberally with Ballistol and that was it.
Ford Bronco rear wiper blade replacement IMG_2570
Ford Bronco rear wiper blade replacement IMG_2569
Ford Bronco rear wiper blade replacement IMG_2571
Like the OP, I applied a LOT of force to remove the blade according to the video but it wasn’t budging. Definitely using some sort of lubricant helped a bunch.
