Rear Window Replacement pic
Happy
Jerry
Missouri
CJ5, Wagoneer
Last year Flip posted a shop manual picture of the rear window schmatics.
This showed that the bolts must be discarded and not re-used.. I can not now find that. Can one of you help and old man? @flip, is it possible to re-post this info?
FleshTuxedo
A
PA
'22 OBX 2dr.
flip
Phil
IN
www.ruxerparts.com
Fords
Special Tool(s) / General Equipment
Interior Trim Remover
Removal
NOTE:
Removal steps in this procedure may contain installation details.
  1. Open the tailgate.
Ford Bronco Rear Window Replacement pic video
Ford Bronco Rear Window Replacement pic Hel
  1. Open the liftgate window glass.
  1. NOTE: Liftgate shown closed for clarity.
    NOTE: Left hand (LH) shown, right hand (RH) similar.
    On both sides.
    Disconnect the heated rear window element electrical connectors.
  1. Remove the rear window wiper motor cover.
    Use the General Equipment: Interior Trim Remover
      Disconnect the rear window wiper motor electrical connector.
    1. Release the retainers and position the rear window wiper motor wiring harness aside.
    Release the rear window wiper motor wiring harness support and position aside.
    Disconnect the rear window washer hose.
    On both sides.
    Release the clips and disconnect the rear window glass liftgate strut.
    1. On both sides.
      Release the rear window glass liftgate strut clip.
    1. On both sides.
      Disconnect the rear window glass liftgate strut.
  1. Release the liftgate window glass hinge trim covers.
  1. Remove the bolts and the liftgate window glass.
    Torque: 97 lb.in (11 Nm)
  1. NOTE: This step is only necessary when installing a new component.
    Remove the liftgate window glass hinge trim covers.
    Remove the rear window wiper motor.
    Refer to: Rear Window Wiper Motor (501-16 Wipers and Washers, Removal and Installation).
    Remove the rear window washer jet.
    Refer to: Rear Window Washer Jet (501-16 Wipers and Washers, Removal and Installation).
    Remove the rear window wiper motor pivot shaft grommet.
    1. Remove the rear window glass weather strip end caps.
    1. Remove the rear window glass weather.
Installation
  1. To install, reverse the removal procedure.
flip
Phil
IN
www.ruxerparts.com
Fords
Removal
NOTE:
    On both sides.
    On both sides.
    1. On both sides.
    1. On both sides.
Installation
Happy
Happy
Jerry
Missouri
CJ5, Wagoneer
Thank you very much. These are now saved.
BigMikey
2022 Bronco Badlands SAS 2.3L
Greetings all! I'm trying to replace my rear glass, picked up a deal on the glass but I need to attach the hinge brackets to it. There are two pieces, one plastic one that attaches to the glass with bolt that goes all the way through from inside of glass to the second piece, a metal bracket attaches on the top to the hardtop. The piece that contacts the glass appears to have been bonded to the glass with some black putty, caulk, gasket maker, not sure. I'm worried I need to get the right stuff and use it properly or the glass will shatter as soon as I tighten the bolt. Anybody have any definitive instructions on attaching the bracket to glass with just the hole precut? Thank you!
Ford Bronco Rear Window Replacement pic PXL_20250628_223824086
Ford Bronco Rear Window Replacement pic PXL_20250628_223656649
Ducati1098
Not sure you’re going to find any instructions on doing this. Ford sells the glass as one part with that piece already installed. Your best bet is to contact a glass company that deals with window installation maybe.
