Rear Window Leaks?
Spoder_Spud
South Carolina
2010 F150
So, I've just noticed this. I've got a 22 Black Diamond and it seems that there is a very small amount of rain water that is able to somehow drip and run down the back glass. Pretty sure that shouldn't be a thing, but has anyone else had this issue. I've check the seals and they seem solid. Any ideas on what I'm missing?
Stick in the Mud
Saco, ME
2023 Bronco Badlands
If the seals are good, maybe try a little silicon lube?
AK SNO RIDER
Ty
Alaska
Is it the middle of the rear glass? Mine did that and I was able to re-seat the seal a bit better and it hasn't since.
harpo
not as many as I thought
Ditto, mine needs to be reseated pretty often, but it is really easy.
Enginerd
Jani
San Diego, CA
Audi S5 Sportback
My rear window seal consistently droops off in the middle and let’s a little water in. I live in SoCal so no big deal but annoyed. I figured instead of dealing with dealer BS just find some appropriate glue or what not, open window and put a clamp on it overnight in the garage but have not gotten around to it yet.
Basically seems whatever adhesive was used either did not get appropriate cure time or not strong enough to hold seal in place. BTW my build was first week of August 2022 justas fyi, everything else has been fairly solid.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there! If you can send over a private message with your VIN and dealership info, I'd be happy to look into this for you.
Paul Gagnon
Paul
Sherwood Park, Alberta, eh?
I have the same issue. If it rains really hard the lip below the window on the inside fills up with water. I believe several others have this problem too.
Spoder_Spud
South Carolina
2010 F150
Yep it's in the middle. I had re-seated it, it had stopped then started again. So guess I'll just give it a push after opening the back glass. Thanks!
FifthCard
Allen
US
Jeep Wrangler Rubicon
I don't have this issue on the back glass. My rear driver side window rattles so not sure if its not tight and making a seal but if its raining hard or even a car wash spraying on the middle of the window right behind driver seat it will leak in slightly. When driving down the roads my kids appreciate the cold air vent ford installed via the window since there are no rear heaters. I took it into the dealer and they told me it was due to me taking off my hard top.
thecaptain
Pasadena
2022 Ford Bronco
I have the same issue with leaking in my '22 Badlands because the rear window seal in the top middle of the rear hatch glass droops down. A substantial amount of water gets in when it rains hard, and right now it's raining heavily in SoCal. If anyone has recommendations re: a particular adhesive to use as a temporary fix before I can get it to a dealer, I'm all ears . . . er, eyes.
Scott R Nelson
Meridian, ID
I just pushed mine back up into place with my fingers. That's all it needed.
lorenphotos
Loren
Woodstock, VT
22 Wildtrack Sasquach Lux
Mine had the droops and after pushing it up several times the dealer glued it and I haven't have any problems since.
thecaptain
Pasadena
2022 Ford Bronco
I did the same thing and it seems to be keeping water out for the time being, but I figure it's just a matter of time before it starts drooping again. I'm thinking some adhesive will be a better temporary fix. Then whenever I take it into the dealer for something else, I'll see if they can make the fix more permanent. Too bad this seems to be an issue with more than just my vehicle.
