Rear view mirror replacement
Aztec1382
Sam
F350
Need help locating a smaller rear view mirror replacement for the base bronco.
The one Currently on there os 10 inches wide. Looking for something that will be a direct replacement and maybe 8inches in length.
Im trying to avoid cutting the oem one but will have to if i cannot find one.
Any help is appreciated
Thanks
AZ_Liberty
2007 Expedition
Rear view mirrors use a standard mount, so just about any mirror should fit.
The Tacoma mirror is a popular replacement. (the one with the built in garage door opener). But I don't know how wide it is.
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
Agreed with the reply above. I’m curious though, why you need a more narrow mirror?
Aztec1382
Aztec1382
Sam
F350
Im trying to use a digital rear view mirror
That clamps over the existing one
However it comes with a forward facing camera as well. Which forces the new mirror to shift to the driver side to clear it.
Ford Bronco Rear view mirror replacement IMG_8771
Ford Bronco Rear view mirror replacement IMG_8772
rws
Robert
GA
2015 VW GTI, 2018 Silverado 1500 LT Z71
This looks like the WolfBox, they have a mount for replacement rather than strapping it onto existing.
Here is the WolfBox link, but i can be found cheaper elsewhere as well.
https://wolfbox.com/products/wolfbox-oem-bracket-for-smart-mirror-for-g900-g850-g840s-g840h
I went with the Wolfbox G930 (10" mirror) and it was a direct replacement for my Bronco's rear view mirror. I used the OEM bracket (as mentioned), and everything has been working perfectly. One more thing, I went with the license plate mounting bracket and hardwire kit for a complete install.
Bottom line, no cutting of anything needed and everything fits and functions in the tight confines of the Bronco interior.
NBPuts
Nick
Atlanta GA
2022 Ford Bronco WildTrak
I went with the Wolfbox G930 (10" mirror) and it was a direct replacement for my Bronco's review mirror. I used the OEM bracket, and everything has been working perfectly. One more thing, I went with the license plate mounting bracket and hardwire kit for a complete install.
I have G900 and really like it so far. I am planning to move my rear camera location based on posts I have recently seen. Can you share what your rear camera image looks like (I am in the same location but want it higher). Also, I feel like its safe but wanted to see if you had any issues with disconnecting the rearview mirror, an installer friend told me I would start to have issues but thus far nothing.
rws
Robert
GA
I replaced my stock bumper, which required me to relocate my license plate, which is inherently much higher than the stock location.
As far as issues removing my original rearview mirror, none that I'm aware of at this point. But I do only have the mid-package [i.e. less electronics] on my Wildtrak, so this may be different for Lux package equipped Broncos.
Ford Bronco Rear view mirror replacement rear_cam_location
NBPuts
Nick
Atlanta GA
Photos of the factory bracket mount. I have th 12” G900 tri pro (biggest one) and I can still use my shades (couldn’t with original mount setup).
Ford Bronco Rear view mirror replacement IMG_0250
Ford Bronco Rear view mirror replacement IMG_0249
Ford Bronco Rear view mirror replacement IMG_0246
  • Like
Reactions: rws
