Rear locker or both?
freebob
bob
michigan
2022 bronco
I wanted to replace my bronco with a new one. Was think of just a black diamond with rear lock..I do light offroad and live in a in the snowy arera. .So do I really need a front locker.?
Area51BS
Ron
Badlands non SAS 4dr 2.3
Others will chime in. But I’m sure less capable vehicles are driving around your area in the winter. In my opinion yes. Just because I believe a 4wd should have all the options within reason and budget to take full advantage of being a 4wd.
dgorsett
colorado
F250, Mustang, Explorer
I've spent 55 years four wheeling, mostly with no locker and did great. Then I got a Rubicon with both and got cocky and stuck some. The rear was real nice to have, the front didn't add much marginal performance. Now the Bronco. With the ifs at least one is essential, these things love to go on three or even two wheels. The front would sure be nice, but I cheaped out and just got the rear. I will say, it keeps me from getting over confident and makes me drive smarter. The rear is an "easy button" the front may be a trouble maker, but would nice to have if you pretended you didn't have it 99% of the time.
Lockers help you get stuck out further.
I agree with "no" - you don't need any locker at all honestly, but it's a nice cheat feature. Even at that, the front is much less useful than the rear (and much more likely to break stuff unintentionally, especially in snow).
RC Bronco
Rob
Kansas
'22 Ford Bronco, '97 Geo Tracker
You don’t need one (front) for what you are describing
I regret not optioning the Sasquatch package. I could get myself into more trouble if I had a front locker and the bigger front axle. Oh well… more money to spend down the line
HighVelocity
Big Sky Country
Pinto
What're you, Leona Helmsley? Say yes to the wide body kit and the computer-controlled suspension. Everything all at once, baby!
Since snow will be involved, Mattracks are a necessity. This requires N2O and supercharger for that V8 as well.
BearPatrol
23 Bronco
I use the rear the most, but it's really nice turning both on & just walking up the obstacle your buddies were struggling on. I call it my easy button.
For snow I'd also consider a set of those 18in wide Icelandic tires.
RNC
Roger
Ohio
2022 Ford Bronco
When it comes to using a front locker, there is a learning curve, and it can get expensive.
G1D1UP
J.
Gilbert, AZ
2024 Ford Bronco Raptor
I didn't like the way my Bronc Rap was looking at other inferior trim models or the way it teased Jeep owners as we passed them going uphill on the Himalayan trails in Nepal. I therefore elected to vasectomy-off my Front/Rear lockers, including the middle locker for good measure. Mechanic asked if I needed the Trail Turn Assist and I boldly said, "I don't plan on turning back around, so hack that off as well..."
Good riddance to all that tech! It's not like I wanted to buy the Most Advanced Factory Off Road Vehicle in existence ....
