Rear cargo enclosure + slide-out tailgate solutions?
dangerfoot
Justin
Austin TX
www.dangerfoot.com
White Wildtrak 4dr
I did get the ez4x4 slide out and molle fold down hatch table. Both work well, closes without hitting and you can adjust the height of the slide out. I had hoped you could fold down the whole enclosure and then put the slide out on top of it (giving you full height of cargo area). But they didn't have proper holes to make that work. Might could drill/tap it yourself though. Overall happy- haven't loaded heavy but works and slides well.
Hey there @indigo montoya is there anything keeping tension on the sides at the top near the roll bar? The OEM trunk rattles when the lid is off.
Fredericksburg texas
Not sure how the Ford version works but with the EZ one the sides bolt into your sidewall and the middle portion is moveable. Look at the videos where they fold it down flat. Short answer is it doesn't rattle when fully closed and locked for me. I did notice rattling the other day and noticed I had left the flip portion open (like in my first picture) so I am sensitive to it. I even bought extra felt pads but haven't had to use them anywhere yet.
23OBX2.7
AB Canada
2023 Bronco
Get HD locking ball bearing sliders online or local industrial supply attach to cargo cover, get the size of 1/4- 1/2" ALU plate needed from metal supermarket etc, use 3M autobody molding tape to attach it to sliders. Cover with whatever surface you want from glue down dry back LVP to carbet to rubber matt.
For under $120 youll have a table that weighs less than 30 lb abled to handle a lot of weight.
irishmurph01
Pat
26’ bronco heritage
The Slipstream only occupies a single bolt on each side, front-most one. It can be modified easily (it is a tab that drops down to catch the bolt). I have one and a slide-out (selling both), had to modify to make them play well together and it was very minor to do.
Did you end up selling them?
CitrusBronco
Everglades
Citrus county, FL
Everglades
I haven't managed to find much info on this so starting a thread to catalogue my search.
I've got a 2022 Everglades that has the slide-out tailgate (love it) and need a cargo enclosure that will work around it. Most of what i've found mounts to the anchor points in the floor, as does the slide-out tailgate, so I need to find something that can either 'share' these mounting points (i.e. stack them) or doesn't require mounting to the floor (ideal).
Did you ever get anywhere with finding one that works?
broadicustomworks
Hanging Rock, North Carolina
Still have both.
If someone wanted both I'd do a package deal for $1K.
Price on the Slipstream is $800, Wicked Relics slide-out now priced at $350.
