Slide-out Tailgate with Cargo Mat?
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Bumping this thread in case any other options came out. Would love to see more offerings especially with the slide out now being standard on some trims.
There’s lots of options at your local hardware store for heavy duty or commercial rubber mats in all kinds of thicknesses. I doubt you’ll find anything an exact fit, but trimming is pretty easy. If you go heavy enough, you may not even need double sided tape on the back to hold it in place.
JTBros
Long Island, New York
GR Corolla
That’ll be the plan for the interim, was originally eyeing the tuxmat but they don’t have any offerings currently.
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
2024 Bronco Everglades 4dr
Everglades
It's ridiculous in year 2024 that neither Ford nor aftermarket titan WeatherTech offer a cargo mat for the rear load area of Broncos spec'd with the slide-out table (tailgate).
And I'm "still" waiting for WeatherTech to offer "Sill Protectors" for the 2-door Broncos.
Callelk
Larry
Idaho
Escalade ESV, Cherokee 2-Door
I used this for the top of my slide-out tailgate. Not very thick but it does not move with my two dog crates on top.
https://www.homedepot.com/p/Traffic...-in-Rubber-Deck-Plate-Mat-MT1003508/206414770
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Digging up this thread from the grave in case it helps someone, as I too was searching for one.
WeatherTech has released a cargo liner specifically for the slide-out tailgate. Don't know when they did it, but I happened to spot it as I was searching.
It's okay. Not as good as the OEM liner I used to have before installing the slide-out tailgate. But something is better than nothing
Ford Bronco Slide-out Tailgate with Cargo Mat? 1747237197974-bq
Also got a video on it if you want to see it more. Roughly 3:00 minute mark.
JTBros
GR Corolla
Bumping this thread in case any other options besides the weather tech have become available. After 2.5 years I finally purchased a slide out tailgate. Unfortunately think not having at mat in my original configuration may have led to some corrosion in my trunk.
Ford Bronco Slide-out Tailgate with Cargo Mat? IMG_3550
Ford Bronco Slide-out Tailgate with Cargo Mat? IMG_3553
