BroncoSarge
Jeffrey
Fort Bragg, North Carolina
Went back and forth on the subject. Should I remove the modular bumper? Should I go with factory, JCR, Rough Country? Sorry Mabett. Your timeline to manufacturing is too long. I decided price was gonna be the defining factor. How far it sticks out, approach angle and other factors weren’t that different.
Rough Country High Winch Mount:
I will say the instructions aren’t that great. I found it much easier to install the bottom half of the mount first. was having a tough time balancing the weight of the mount and winch to attach it to the bumper. Mounting the bottom half gave me room to get my hands in there as well. Then I mounted the winch to the plate. I followed up by wiring it, then mounting the top plate to the bottom half. The instructions also call for shaving down the back of the sensor they provide. This was not the case with the winch I chose. I think each winch will differ in that step.
Smittybilt Winch:
Pretty cut and dry. I just wired the longer cables before I bolted the plate down. It’s tough to work behind the RC mount, it’s pretty tight to the grill. Removed all the decals and painted the “Smittybilt” and the switch for free spool.
https://www.amazon.com/dp/B00K150VAI?ref_=cm_sw_r_cp_ud_dp_X9K6SBMZCMGCJKQ54PAT
Control Box Relocation:
I decided to mount it to the lid of the fuse box. Was a simple install and it wasn't going to eat up space on the other side of the motor. Saving that for ARB compressor and maybe train horn. I used the Warn kit. Only needed the cables and black rubber boots.
https://www.amazon.com/dp/B00ANYN2G2?_encoding=UTF8&psc=1&ref_=cm_sw_r_ud_dp_R4PZ7CFEPPNMRR261BBV
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 823ED22B-A6CB-4AF2-AA09-6198561E02DC
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation E7AF1904-8055-4FB1-8A4F-BF3B8FF99DE2
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 74A93C72-0E6B-428D-B07F-CAF9A6380D4A
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation A098518A-7B06-498B-A605-2352BD39F5B6
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 66576545-99DB-490B-A9DB-B282E1B4D9B1
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 82F3EC10-5811-4303-8E79-866659892B7D
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 4DD06805-95F6-46D7-B6A3-C7238081C476
Hossamus Prime
Arkansas
www.instagram.com
21 BadSquatch,‘21 ExplorerST , RIP 84 & 90 Broncos
Did you remove the bumper to install? Seen some have had to for the sensors.
Jpursuit
J
Houston
2008 f250 king ranch 4wd, 2021 Bronco
Nice job! I'm looking at doing a similar setup. Could you post what you're front camera sees? And, what did you use to remove the stickers? DId you paint the entire winch?
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
How’s the front camera blockage? Relo needed or did moving the Control Box do the trick?
BroncoSarge
BroncoSarge
Jeffrey
I took off the bumper. I did not remove the shackle or back plate though. I was an;e to pop loose the sensors with a small screwdriver. Then I attached the cable extentions RC included to keep from losing the plugs back into the bumper.
BroncoSarge
BroncoSarge
Jeffrey
The decals came off clean except the yellow one. Used goo gone on that one. only painted the “SMITTYBILT” spool switch on top. They are easy to remove, paint and put back on.
BroncoSarge
BroncoSarge
Jeffrey
The camera is still blocked atm. I don’t use it much anyway. RC says a relocation kit is coming soon. If not, I can use the one that JCR sells.
Rubisquatch
Pittsburgh, PA
2021 Bronco Wildrak
Nice work, can we see some more pics such as side shot and a bit further away showing whole. Upper.
Gene Dios
Atlanta
Mind posting a photo of the front cam on screen showing how much coverage the winch has?
okbob
North of the Red
71' u15, 66' u14, 66' u14
I started out not removing mine, but got a sensor sideways back there and couldn't get it turned around to retrieve it. I just sit unhooked the main harness plug on the drivers side, sit in a chair right in front of the bumper, impact the six bolts out and took the bumper off and sit across my knees, then stood up and then sit it across the chair arms, did the sensor work and then put it back on. The bumper hangs in the front end when not bolted in, it won't just fall on the floor when the bolts come out.
BroncoSarge
BroncoSarge
Jeffrey
Sure.
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 501659DC-26FD-4E2C-82EF-DF84E8797E20
Here is one with and without the decals.
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 98F61B45-7985-4097-830C-F56F4032EF27
Here are some measurements I have done.
Barely 1.5” from the grill to the winch. Nicely tucked in.
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 77E0B0CF-46EB-41E0-BD34-23B82BA611A6
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 21E76847-2A64-475A-A9F1-BBA168E21698
Height of the winch w/o the control box is about 2” below the Bronco letters.
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 2B79E9BE-EC54-446C-A49F-910B59F981F1
The winch and Winch mount distance from the grill face.
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 0C28F991-77D1-4433-9D52-14A846DBA1DF
Vellicate
James
2018 F150, 2014 Flex Limited
Sure.
Very nice setup! Just finished mine up over the weekend, I relocated my control box to the passenger side since I don't plan on running a compressor. I ordered a JCR camera bracket as well, hoping to see that soon.
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation inbound7034940434603417980
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation inbound162902971580131311
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation inbound2231653323137747076
‘21OBX
90Bronco19
2022 bronco outer banks
Wow! I like the fact that the wires are on the back side of the winch. It’s a much cleaner look! That’s the same place I mounted my controls. Not enough to remove the one I have but If it ever fails I’d switch for that reason.
Blksn955.o
Greg
Wentzville, MO
Waiting for my RC mount to ship. I spent a little bit of time and completely disassembled the Badlands Apex control box guts. Plan is to attach to the frame horns you would cut off with the remote rc mount and extend the Bluetooth switch, Bluetooth module, and hardline plug to the top of the front radiator support.
BroncoSarge
BroncoSarge
Jeffrey
Looks great!
