okbob
North of the Red
71' u15, 66' u14, 66' u14
For those of you that have installed the RC winch mount, how hard would it be to remove/put back after you've done the initial install? I'm thinking about getting this but I don't want to run it permanently and I'm ok with the idea of spending an hour putting it back on for when I might need it.
It can be done in an hour with the right tools, especially once you've done it. Even if you have to move the front camera back into the bumper I think it can be done in an hour. I used an impact or cordless impact for everything, so that speeds things up greatly. Hand tools will definitely slow you down.
Jdc
Jon
Massachusetts
Bronco Badlands
Nice! That's what I was hoping for. Thanks for the response!
BroncoSarge
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
2021 AMB Bronco, 2021 CO Bronco
The two plastic bumper pieces are cut to fit. You would have to replace them or drive around without them while you’re deciding. Hers are off and mine are cut to fit and on. Ignore the crappy image. I blasted contrast to be able to see better.
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 40982F8C-E50A-4CF7-929E-AB254C1AC428
Jdc
Jon
Massachusetts
Bronco Badlands
Thanks for the update and yeah I read the install instructions and figured it was factored into RC's estimate of 2-3 hours for the install time.
Blksn955.o
Greg
Wentzville, MO
17 Ford Escape Ti, 94 Ford Mustang GT, 21 BL
Finished installing my RC high mount yesterday. Cut the plastics Sunday and it was too hot so that is all I did (inside to cut them).
Installed the actual mount Monday after work and put the winch plate/winch. Ran the cables to their basic spots.
Made my connections and tested last night.
I disassembled my HF Apex controller piece stripping the guts out of it. I want to extend the 16ga or so wires but have them zip tied out of the way for now.
  • Like
Reactions: Jdc
BroncoSarge
BroncoSarge
Jeffrey
Looking forward to pics.
Blksn955.o
Greg
Wentzville, MO
here are some pics.
I did not install the rc light grill thing. I noticed you can't really get it on and off with the winch mount installed. I plan on getting a diode dynamics 3 bar light bar.
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 20220727_174454
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 20220727_174558
The control relay is in the void under the air box inlet. Honestly between the 3 battery cables and the main power line the box does not move much. I do want to extend the 16ga ends to the plastic radiator support cover this weekend. I just zip tied them out of the way to drive.
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 20220727_174630
you can kind of make out the main power wire and red covered winch wire. The wire with red at the 12 o'clock is the battery power. The red below that is the plastic cover for the red winch control pack. The bare head at 3 o'clock is the yellow where the boot fell off.
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 20220727_174703
BroncoSarge
BroncoSarge
Jeffrey
here are some pics.
Nice job. Great jnstall
Vellicate
James
2018 F150, 2014 Flex Limited
Did you make this yourself or find a bracket for the Badland control unit? I have to also find a place to add it to under my hood.
I made the bracket myself from some scrap metal I had laying around. Luckily the ugly welds are hidden by the control box. 🤣
Hossamus Prime
Arkansas
www.instagram.com
21 BadSquatch,‘21 ExplorerST , RIP 84 & 90 Broncos
Custom camera relocation.
I must be blind because I don’t see it. Could post what the camera sees as well?
66GT
Thomas
Tacoma, WA
03 Marauder, 66 Mustang GT, 65 Ranchero, 64 Comet
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 20220807_203117
It's pretty subtle.
The extension for the camera cable I ordered thru Amazon didn't work. The replacement comes in tomorrow. I'll take pics and post.
I did a test run for aiming it with the camera close to that position... and at the same angle. It looked just fine... 100% view... and only about 6" lower than most relocation kits. (I would have taken a pic of that test run if I realized the cable wasn't going to work.)
Hossamus Prime
Arkansas
www.instagram.com
It's pretty subtle.
That is impressive!!! Rough Country should pay you, and start supplying the mounts with the option to do this.
Raskew
Rick
Vancouver, BC
1970 Bronco, 2018 Stinger
It's pretty subtle.
Do you have the ACC? Does it still work?
