Rattle under driver dash
Treypal
Trey
New Braunfels TX
13 F350, 14 Raptor, 20 Raptor
Our Bronco has a super annoying rattle/paper-flapping sound under the dash at speed. I have zip-tied everything off that seems loose including the hvac vent, cut off all the paper tags on all of the lines under the hood, and cannot figure it out. Is anyone else experiencing this?
Theherofails
Thomas
Phoenix
Nope. There is a large rubber grommet in the firewall behind the driver dash - you can see it from under the hood if you look at the driver side firewall. It's near the upfitter wiring if you have the upfitters.. I would check there. Direct path into the engine bay and quite a lot of noise can make it in if that grommet is missing.
Also, the clasp cover above the drivers head can vibrate and cause sounds quite easily that sound like they're coming from random places in the passenger compartment. Give it a wiggle and see if it moves quite a bit. I have a hardtop, so I can only assume its the same in the soft top.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hey there! I can look into your Bronco’s rattle concerns on my end if you’d like. Will you send us a private message with your VIN and dealership info?
John94
Detroit
4dr Black Diamond Sas
Did you ever resolve this?
I imagine its similar to the rattle I see being reported elsewhere on the site.
Could be a mispositioned shifter cable
KaiBN
Ikaika
Portland OR
2023 Bronco 2DR
I’m experiencing this same issue underneath the drivers dash. I’d typically happens when the vehicle loses traction or is at full articulation.
and no it isn’t a tire rubbing. It’s a metallic vibration. Very annoying when it’s supposed to be relative smooth through the rough stuff.
Went to the dealership twice and they were unable to replicate the issue. My third try is this Friday and I will be taking them for a drive.
This has been an issue since new.
Ford Motor Company
Dearborn
Good afternoon, Ikaika! I would be glad to help you out with this dash rattle concern if you are still need of assistance. Just shoot us a PM with your VIN and dealer name/location, and I'll get right on it. To send a private message, just click on our username and select "Start Conversation". Thank you!
OuterJersey
Honda, Toyota,VW, Lexus, Triumph, Honda MC
Every 1,000 miles I get a new squeak rattle or moan. Never had a new vehicle do this and I’m not really 4-wheeling it. Latest is I think the back seat squeaking when I hit a bump
Yup. It’s a running joke with my wife - as soon as I get the last rattle fixed, it’s a matter of hours before a new one pops up someplace
brybar4
2022 Ford Bronco
I've been experiencing this as well. Typically hear it at speeds 50mph or higher. Likely something with the airflow under the hood but I've tied down everything and it's still there! Help Ford!
Rdaly101
Rhode Island
2022 Bronco
Just had the same thing happen on my ‘22 Big Bend. Seems to be driver’s side and mostly when I hit 2200 RPM then goes away at 3400 RPM. Did anyone get any answers?
Techun
Pa
BD, 2.7, MIC, 4dr
I fixed something similar to this, by the driver's left foot there is kind of like a push pin connector securing a wire. Mine was not deeply seated, I pushed it and then a particular rattle went away for me.
Rdaly101
Rhode Island
2022 Bronco
Now it seems to be any time I accelerate. If I'm idle it fine.
Hot Pepper Diamond
Justin
Knoxville, TN
Bronco Black Diamond 4 door
Has anyone figured out what this was or a solution? I have had this happening with mine as well and have yet to figure it out.
vbrad26
Vance
FL
VW's, an old Range Rover and now a Ford
I too thought I had a rattle coming from under the dash. Usually would present around 45-55 mph and go away.
Turns out, it was my airbag. Though it sounded like it was coming from lower - I found that if I just put a little pressure on the center of the steering wheel, the rattle would go away.
But once I took my hand off of it, it came back.
You all could have another issue entirely, but this was my experience.
Hot Pepper Diamond
Justin
Knoxville, TN
yeah, I guess if I was honking my horn I wouldn’t hear it 🤦🏻
