Rattle coming from the passenger side dash.
Last Ride Bronco
southern USA
Nissan pup
I’ve had my Bronco for 8 months, 15k. Enjoyed every mile and minute. In the last few days, Ive noticed a rattle coming from the passenger side dash. I can apply pressure to the dash with my hand and the rattle stops. Is there anyway to tighten the dash without opening everything up? It’s nothing I can’t live with, but I would like to address it if its not a situation where trying to fix one problem creates 3 more. Thanks for any input.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there. This rattle concern doesn’t sound like something we want you to experience with your Bronco. Could you please send us a PM with your VIN and the name and location of your Ford dealer? I'd be happy to look into how I can assist you on my end.
threeonone
Canada
Jaguar
Does it sound like this?
CplusB
2022 Bronco
Whoa! I have that same insane rattle! 4dr / soft-top. It's been driving me completely bananas for the last few weeks.
I've been casually searching online and on the forum and finally found this thread and your post.
Threeonone, did you ever diagnose and fix? I see that this thread ended but I'm curious.
I've had no luck finding it and less help with a friend searching while I'm driving.
Thanks for any intel -
BasicBlu
Darrell
MaggieGirl2022
2021 Anti Matter Blue base Bronco
I’ve had a similar sound with front windows 1/2 down and went over rough set of R.R. Tracks. Thought the frameless window on passenger side was going to fly off. Now I only drive windows full up or full down.
CplusB
2022 Bronco
Yes, the partially-open-window-rattle is very well-documented fun with these Broncos. Cost of a lot of frameless glass.
This particular rattle happens with windows full up or down. It's interior-born.
Ford Motor Company
Dearborn
Hi there, Darrell! Will you send us a message with your VIN and dealership info? I can look into things on my end.
Havanajoe
Sarasota Fla
Audi S5 coupe. Tesla Model Y
My dash and front passenger seat started rattling today (day 6 of ownership)
it’s not constant but started today.
Lak34ers
Troy
Seattle
Look at the speaker. Mine had some wiring that was making a noise. Upgraded all the speakers and bought some quiet tape and wrapped wires anything that could rattle really good. Things will rattle so the tape is nice to have on hand. Hush Mat Quiet Tape on amazon
Ford Motor Company
Dearborn
Hey there! I can look into your Bronco’s rattle concerns on my end if you’d like. Will you send us a private message with your VIN and dealership info?
el_june
Vic
Chula Vista, CA
2024 Bronco
I had a similar rattling sound on the driver side that got louder as my speed increased. It turns out the bolts on the hood hinge were not tightened properly. Might not be your case but worth checking it out.
feralc
Fernando
Outerbanks
Hello I have been dealing with this extremely annoying sound and I think I found a solution after SO many things that I tried.
I am actually glad that Ford has replied to this thread so maybe this post could help to develop a solution or TSB
Mine was on the drivers side and at the beginning I thought it was the airbag because I read this other thread
https://www.bronco6g.com/forum/thre...s-on-the-a-pillar-and-a-few-other-bugs.29039/
And that is why in the video the airbag covers were off, but it is not, the culprit is the metal plates where the hard top connects to.
Somehow if they are too tight the noise eventually develops, maybe because of the flexing of the body etc.
As I said I hunted this sound for literally weeks and and the solution was to loosen up the torx screws that hold the metal plates, and literally just tighten them BY HAND and then just add just a tiny bit of extra tightness with the ratchet, but no more than an inch of movement of the ratchet. That will secure the metal plates without that extra tightness that would make the rattling noise come back.
I will repost this same explanation as a brand new thread because it is not the dash but the top.
I hope this info helps and Ford eventually install some sound deadening tape or something to make a permanent solution.
Here is the video and a picture of the plates that make the sound of they are too tight.
Ford Bronco Rattle coming from the passenger side dash. A4B77ED5-0B79-4244-B3C3-C48F69A18F6A
Mattymillz
San Jose, CA
2023 Ford Bronco
did you solve this? i have the same issue. at first i thought it was coming from down low, like where the front passengers foot would be. but now I think it might be something on the A pillar like the plastic trim rubbing the metal frame.
Jossman
1979 F150,2011 Mustang,2013 F150,2006 HD
I had a rattle which turned out to be seat belt hitting the side on bumps.Just fastened the belt to console latch when passenger side is empty.
dangerfoot
Justin
Austin TX
www.dangerfoot.com
White Wildtrak 4dr
Mine is def rattling at the dash - if I press the face that faces the passenger, it stops. Lame and hard to find a way to quiet it
