Raptor wire harness repair released
MGF
CA
Bronco Raptor, Merc AMG C63S, Range Rover Sport PHEV, BMW 328i
Had my Raptor in this morning for a right front wheel flare attachment pin replacement and they told me the repair is out for the wire harness recall and printed it for me. It checks an upper small wire harness on LH and RH side that runs along the front fenders and a larger harness on the RH side that runs behind the fender liner. Inspect and add colorplast tape and convolute tubing, zip ties. More involved if damage found.
MDrums
Tampa
Bronco Raptor
Did they do the repair or just getting info and letting you know? I got a recall notice from CarFax but nothing from Ford yet and yesterday afternoon when I was having the Ford ProCal Tune installed they did not know anything about the recall. Thanks for posting this...going out to the garage to have another poke around and see how much of the harness I can see that you mentioned
MGF
MGF
CA
They will order the supplies and then complete the repair in a week or so.
MGF
MGF
CA
dgorsett
colorado
F250, Mustang, Explorer
Thanks for this. Having a little trouble figuring out the first picture: It's take inside fenderwell with inner fender liner removed? Passenger side? Sheathing the harness behind the washer bottle? It looks like the wire by the hood hinge on both sides is also involved, but that is all on the drivers side, correct?
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
See this post's attachments on the main thread dealing with this recall. The diagrams in the pdf attachments are color coded so it is easier to see.
MGF
MGF
CA
Yes the top bundles run from hinge forward along inside fender down to wheel well. Both driver and passenger are inspected and taped. Just the passenger wheel liner gets pulled and that bigger harness gets inspected, taped, and corrugated.
