Raptor R 5.2 V8 engine swap
22luxobx
Las Vegas, NV
2018 Ford F-150 SE
I believe Loren Healey is working on a Godzilla swap to work with all electronics currently so excited to see how it turns out and can’t wait to ask for his input as I’d love to coyote swap mine!!
CarmeloS
Carmelo
Central Jersey
Had me at Manual Coyote
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
Wow! Tagging the big boys @BigMeatsBronco @Bmadda @TeocaliMG
Loren for sure has the connections at Ford Performance to get all the electronic stuff figured out. Praying they come up with a kit!
BigMeatsBronco
Allan
2021 FE 2 door
I spoke with Lauren about this and on his builds. on the 5.2, they didn't hook up any of the electrical dew. Hickeys...they run a th400 race prepped trans. No goat modes work, ABS is removed, NONE of the factory modules are retained on that build. In other words, they did it the easiest way possible. When I do this, I intend to keep all of the electrical. Dew, hickeys, intact and make everything work. As good or better than factory, including lane centering.
it will be great to see the 7.3 working with all the electronic stuff intact. Even though I don't believe a antiquated push-rod motor belongs in the bronco.
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
I spoke with Lauren about this and on his build. They didn't hook up any of the electrical dew. Hickeys...they run a th400 race prepped trans. No goat modes work, ABS is removed, NONE of the factory modules are retained on that build. In other words, they did it the easiest way possible. When I do this, I intend to keep all of the electrical. Dew, hickeys, intact and make everything work. As good or better than factory, including lane centering
Ah dang!! I was hoping they were trying to set it up like you were.
Welp, you really will be the pioneer on this my man!
Aonarch
Jack Hoff
MT
I've put a lot of research in time into this and it's totally doable and all the electrical doohickeys and Wizardry can be figured out pretty easily the biggest hurdle is the initial cost.
Start an OnlyFans?
BigMeatsBronco
Allan
2021 FE 2 door
These guys at Lone Star Axle claim they're about to get the computer figured out on a Godzilla swap:
And yes, that is an authentic East Texas drawl. :LOL:
@BigMeatsBronco
Sad to see they stuck in a solid front axle.
This makes one wonder if they just don't wanna build a new oil pan that fits around the factory fdu? So they changed the steering. Now it doesn't have advanced cruise control, Trail turn assist, or stability control. Cheese d*** red necked way to do it in my opinion.
Aonarch
Jack Hoff
MT
I was going to say, that is a much easier way of doing this.
Strip it down to the frame.
Convert the front to a 3 link.
Run hydro steering.
Have the ECM be stripped down to the bare minimums.
BCM stripped down to the bare minimums.
userdude
Denton, TX
2023 2dr Badsquatch
Well, they are an axle company... lol Personally could care less about ACC and TTA, but I get that others do. I just wouldn't be worried about it for myself.
And I gotta say this is the first time I've every seen a serious off roader bemoan a SAS... :whistle:
BigMeatsBronco
Allan
2021 FE 2 door
Run hydro steering.
No thanks!!! adding a few hp with an oversized-antiquated NA v8 is NOT worth making it ride like shit, steer like a jeep, have NO ABS and traction control, no cruise controll, no trail turn assist, ect... There's NO way that ugly front axle has the correct ABS tone ring, trust me.
What a caveman build with no brains, all Brawn.
the 460hp 5.0 is a better option!
and the 760 hp 5.2 is the best choice!
userdude
Denton, TX
2023 2dr Badsquatch
Aren't you kinda describing the KOH Bronco rigs? For a daily driver, sure, but for a tow in who cares.
BigMeatsBronco
Allan
2021 FE 2 door
Im not the only guy that hates solid front axles...I've never been a fan of solid front Axles... All my serious rigs have been independent front suspension, and will continue to be that way. I was so glad to see king of the hammers Come about and watch the ifs/irs Rigs beat the solid the front axle junk! Even my semi truck has 6 wheel Independent suspension.
I truly believe the solid front axle is as antiquated as the model t.
Ford Bronco Raptor R 5.2 V8 engine swap 20240526_091213
Ford Bronco Raptor R 5.2 V8 engine swap 20240526_091149
Ford Bronco Raptor R 5.2 V8 engine swap 20240526_091129
userdude
Denton, TX
2023 2dr Badsquatch
How do we get you setup to make the Bronco of your dreams? Share program w/buy-in or go fund me? I want to see what you want happen.
BigMeatsBronco
Allan
2021 FE 2 door
Have yet to see any newer 6g Broncos competing at KOH with a solid front axle swap. And I hope I never do.
