Question regarding tongue weight
Mikerkelly
Canyon Lake, TX
2022 Bronco
Hey everyone,
I recently bought this hitch basket to store some extra gear on while camping. It's the same one on the Ford accessory site but I saved like $200 by going through Amazon with the manufacturer part number.
CURT 18151 60 x 20-Inch Basket... https://www.amazon.com/dp/B00JF5HR7K?ref=ppx_pop_mob_ap_share
My issue with it is that the Sasquatch tire is too large to allow opening the swing gate without taking off the basket.
Ford Bronco Question regarding tongue weight 20230120_145822
I need to drop it by maybe an inch or two.
My questions are
1) Any recommendations on an affordable hitch drop?
2) Would dropping it effect tongue weight at all?
I know that the max tongue weight of the Bronco is 350lbs. The basket supports 500lbs and weighs ~60lbs so I'd never plan on exceeding 200-250lbs of gear just to be safe, but was wondering if somebody here knows if a hitch drop to allow the swing gate to open would further impact the max tongue weight.
Thanks in advance to anybody willing to dish out some education.
rtazz17
Connecticut
2022 Ford bronco big bend
I dont see how it would. An extension drops the tongue weight. There is some calculation for that.
MnLakeBum
MN and FL
‘18 Range Rover Diesel
WheresMyBronco
Los Angeles
2023 Badlands
You'd be changing the geometry a bit by doing so and it might affect the torque applied from the weight of the basket/stuff, but dropping it by an inch or two shouldn't make enough of a difference to really be a risk. Just keep a small cushion between loaded weight and tongue weight limit (which you were already doing) and you'll be fine.
Mikerkelly
Mikerkelly
Canyon Lake, TX
2022 Bronco
Thank you, ultimately I had an idea this would be the answer just wasn't sure.
BigHoof
PA
Ram 2500
How much weight do you plan on placing in the basket?
Mikerkelly
Mikerkelly
Canyon Lake, TX
2022 Bronco
An ice chest, some recovery gear, and maybe some wood for a campfire. I don't think I'd even exceed 200lbs if I'm being honest.
