PSA - Fix Non Functional Raptor "R" Button
swamp2
After a dealer service this steering wheel button became entirely non functional. It wouldn't restore or memorize a set of vehicle settings. I found some positive advice on another forum about disconnecting the battery. This did not work for me when disconnecting for a minute or so, but luckily did work after disconnecting for about an hour. Hope this helps others.
8oncoPete
Pete
Connecticut
2023 Raptor and 2024 BMW i7 / 2019 BMW X5m
Thats how I fixed mine! Havent had the issue repeat since the reset.
swamp2
swamp2
Crap, switch went out again today. I'm sure a dealer can't even investigate... I use this button at every startup.
monsterfd
2014 raptor widebody 37s, 2018 raptor 2018 JKU 35s
that sucks. i feel that reason everything gets reset after ignition off is so that button gets used, wouldnt be a big problem if it just kept the settings between starts
HeliPilot
Kenny
CT
2022 2.7L SAS
I have my bronco as well as an F-150 Raptor. While my button hasn’t had any issues, I know I’ve seen a few threads on the issue over on the Ford Raptor Forum. You may way to go take a Quick Look to see if they’ve come up with any different fixes.
vrtical
Doug
GSMNP, TN
Fords
My R button stopped working for about a week when it was new, but about another 2 weeks it started to work again and I haven't had an issue since. I didn't do a battery reset either soo don't know, but this is something that is happening seeing more of it.
swamp2
swamp2
Hmmm, working on some other larger mods so been too lazy to do another "battery reset", but viola, after ignoring the lack of the R button for a few days it started working again. Odd.
DillonC
Dillon
Ga
2012 f250, 2019 expedition
My 24MY raptor just started doing this yesterday and today.
The seek buttons on the wheel also just randomly didn't work on one drive like last week.
MidwayJ
Mid
Bronco Raptor
Mine has been out about a week. Saw the battery disconnect fix on another forum somewhere through Google search results and didn't fix it for me. I used this every start. Too many issues for a 6 week old car with 1800 miles.
swamp2
swamp2
@MidwayJ , did you leave the battery disconnected for 10 mins or so? I think my first attempt didn't work with a quick disconnect period. GL.
MidwayJ
Mid
Bronco Raptor
I didn't time it but I would say right around the 10 minute mark. Maybe I try again and leave it off for longer. I'll let the group know if that helps - appreciate the response!
MidwayJ
Mid
Bronco Raptor
Just as a follow up, I left it disconnected for several hours and still no R button. All other buttons on the steering wheel appear to be working just fine - so odd.
swamp2
swamp2
Rats @MidwayJ . I use mine every time I start up. GL. Keep us posted.
MidwayJ
Mid
Bronco Raptor
Update: The R button started working a few days ago seemingly for no reason. It worked for those 3-4 days and it's back out again. I find that disconnecting the battery does absolutely nothing in my specific case. I did once get a message that I was not quick enough to get a picture of that I believe said "My view not available". This does not come up every time - I may have seen it once or twice. The mystery of the faulty R button continues.
swamp2
swamp2
Minor update here as well. Mine stopped working for a day, but came back after sitting overnight before I got motivated to disconnect the battery...). To be clear, it came back spontaneously, as I did nothing to "fix" it.
