Beautiful & Functional - Monster Hooks Rock Rings
swamp2
Having adopted soft shackles and not liking the sacrificed departure clearance and aesthetics of the rear factory recovery points, I picked up these beautiful, beefy MHI Rock Rings.
Solid 7075-T6, CNCed, aluminum. 15,000 lb working load, 60,000+ lb breaking strength. I calculated the bolts would probably shear first around 20,000 lb
EDIT: According to MHI on strength: The OEM bolts failed at around 35,000lbs. We then tried Grade 8 bolts, those failed at around 30,000lbs
Second pic shows the view standing behind the truck. They are invisible!
Ford Bronco Beautiful & Functional - Monster Hooks Rock Rings PXL_20240126_182322986
Ford Bronco Beautiful & Functional - Monster Hooks Rock Rings PXL_20240126_182259339
Install is trivial, use low strength blue loctite (as the factory did) and torque to 59 ft lb.
swamp2
swamp2
That's a legitimate concern/reservation @Doc TOC . My plan (and backup) to easily avoid any such occurrence of this "problem" is very simple.
1. I always carry my soft shackles
2. I have and carry a Hitchlink
These may not have quite the same flexibility as the giant ugly loop things from the factory, but the factory front of the truck doesn't have that flexibility either.
1st 75th ranger
jeffrey
nj
cool but i like my d rings showing
351W-Bronco
Herb
Southern New Mexico
2023 Bronco,1969 Bronco, 2001 Excursion (7.3L)
My concern would be having my recovery points being tucked so far under my rig. Depending on the angle of the recovery, the soft shackle or recovery rope could easily be scraping across the bottom of my rig.
JohnGalt
Tahoe, CA
2023 Defender 110
I’ve got a pair of well scraped up “giant ugly loop things” for sale.
They needed to go and this one good solution. Seems like a good, clean first step to clearing the departure area. And as you say, if you carry soft shackles and a hitch point (I do too) there is really no down side to this swap out,
The only potential down side going forward is when you discover that the next low point is your OEM bumper and those hooks likely become obsolete. I just opted to make the expensive leap straight to the aftermarket bumper.
