PSA: check your blind spot wires
DCblue
'22 OBX
wtf, the MSRP on that connector/harness (FU2Z-14S411-ADB) is $181.27!!!
Those are Porsche prices.
PrepVet
North Central WI
A bunch.
When I was having 2 or 3 recalls done I had them fix the wires are the dealership. $250 for the fix.
Aknobronco
Ak
Gulf States
F150 F350 Wrangler Taurus Mustang Camaro Cmax
Another Jim Farley epic failure.
Charges more for 360 and mediocre workmanship! Great job no neck Jim Fartley!
CalvinT
Calvin
Phoenix, AZ
I looked at mine (warrantry expires at end of the month). They look fine. They're not rubbing or touching anything and seem reasonably well protected. It seems routing is inconsistent from one Bronco to another. The wires would definitely be exposed to damage if someone did a lift.
I may drop the bumper and give the wires some more protection.
Wildruby
Canada
I had the same thing with mine. It started to screw up my bronco where the hvac controls wouldn’t work, the windows didn’t work - which means they wouldn’t go down when you opened or closed the door which screws it up big time.
Warranty - fixed that wire
