Procal Tune versions changes
RoverDude
Maryland
2021 Bronco (First Edition)
There is no public change log for the modules associated with the Procal File Tune.
I recently plugged my unit back into the windows app and I notes new iteration of the tunes based on its file name.
I do not know if this newer version removes the Start stop being able to be permanently turned off
I am looking anyone's insight to when the Start Stop was removed. i am looking to crowdsource this information)
Clearly I do not want to update the installed tune if the update just removes a feature.
If anyone knows what do the SW: and Match mean?
Below is from a 2.7 4door if that matters
Performance Cal listed in ProCal Windows App
Currently Installed
02/09/24
02/28/23
SW:
MB3A-FPB-27A-DJE
MB3A-FPB-27A-DJE
MB3A-14C204-DJC
MB3A-FPB-27A-DJF.bin
Match
MB3A-FPB-27A-DJC
MB3A-FPB-27A-DJC
DLCM
MB3A-14G576-AN
MB3A-14G576-AM
MB3A-14G576-AM
Rack
MB3C-14D007-AGE
MB3C-14D003-AB
MB3C-14D003-AB
Start/Stop Off is Remembered
Stays Off
Stays Off
Stays Off
My understanding was ASS and Rev Matching were removed in June 2024, for MY23 and higher only.
But - proceed at your own risk.
RoverDude
RoverDude
Maryland
Follow up
Has anyone with a MY21 or MY22 updated and lost that feature.
Is anyone have MB3A-FPB-27A-DJF installed, and is start stop disabled?
userdude
Jared
Denton, TX
2023 2dr Badsquatch
If you update, you're most likely to lose valuable settings like Brian mentions. I wouldn't. I have a 23 and it's never getting updated, since I still have the ASS setting remember. I also tell service when I bring it in NOT to update if they think they want to.
EDIT: And yes, there have been people on here that have updated and reported they lost those features. Some were done at service, which is why I say not to.
RoverDude
RoverDude
Maryland
Out of curiosity and you plugged the ProCal into your car then go to module info, what versions does it show currently installed on the vehicle?
RoverDude
RoverDude
Maryland
You're running a 2.3
This information be useful for others as well. Knowing at least up to this version,- HC should still have the start stop.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
I bought mine in late July/early August of 2023 right when they came out for the 23's. (Maybe it was just the 2.3L only.) Then it seemed like a couple months later we heard they were losing ASS setting and rev matching. I don't recall exactly when those versions came out, but it seems like it was starting in September/October 23? But maybe it was when the 24's came out a year later and became retroactive. I don't recall exactly but I know I slipped right under the cutoff.
Ducati1098
It’s all by build date.
Newer updates don’t necessarily change the way the auto/start stop function works on every Bronco.
I’ve installed a handful over the last year. Some will still have the memory function with the newest update for that specific Bronco, others won’t.
That being said, I don’t have anyway to narrow down or definitively say which will or won’t. I think that’ll be pretty difficult find. But hopefully if enough people look at theirs, you’ll be able to get an idea.
If I had to guess, I’d say 21 - early/mid 23 will most likely still have it regardless if you update, anything after I don’t know though.
JL8jeff
Ewing, NJ
I installed the Procal tune on my 23 2.7 Sas back in Nov 2024. ASS is disabled with that original tune install. I was looking at my Procal software the other day and my VIN and stock tune is missing so I ran the updated but it's still missing so I reached out to FPP and waiting to hear back.
My truck is a Jan 2023 build.
Ford Bronco Procal Tune versions changes MyBronco_Procal3
Ford Bronco Procal Tune versions changes MyBronco_Procal2a
RoverDude
RoverDude
Maryland
I am recording all this in spreadsheet. (will give a link when I have 10+ vehicles)
Clearly the more data the better.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
Interesting! I thought they were backporting it. I know I've seen some people complain about losing it, but c'mon, I guess it is Ford here... And Ford Performance no doubt... Maybe we're lucky it works at all! :whistle:
dougcjohn
Doug
Iowa
‘24 F450 Limited, ‘25 Bronco Raptor, ‘16 Smart Fortwo, ZX12R
Yep… never had the ForScan benefit for my 25, that was a disappointment… I was looking forward to turning it off. But the $90 module is nothing to install and resolve even if you do loose it.
Moe-Jave
SE AZ
2022 Bronco Badlands (2dr/manual); 2023 Jeep Gladiator Mojave
Follow up
MY22 2D Manual, Badlands. Auto Stop/Start is fine (stays off) but I do not have the rev match feature with my ProCal (I’d like it enabled!).
RoverDude
RoverDude
Maryland
Can you post what the software versions of the modules are currently.
It'll be helpful to know and what version that was removed
