Powering your fridge/freezer?
Raskew
Rick
Vancouver, BC
1970 Bronco, 2018 Stinger
I get that there is a 12V plug in the back to power your fancy refrigerator while driving, but what system are you guys using when parked for extended periods of time.
And why did you choose the system you chose?
I would love to hear.
Thanks
Rick
8cam
Georgia
Corvette
I actually built one using a Redarc controller and a LiFePO battery inside a gun case from Harbor Freight. I enjoyed the project and I learned a lot, and it works really well. But there are plenty of turnkey battery systems out there too.
VIRUS
D
Wisconsin
Truck, car, feet
I don't have my Bronco yet but there's lots of videos from YouTube that cover this topic. I came across it when I searched for overland rig setup or something like that. Most of the people on there go into detail on what they have and what they have tried. What works best for them
Jdc
Jon
Massachusetts
Bronco Badlands
I built one using a tool box. It was definitely educational. I feel like the number of companies making these has exploded over the last couple of years.
dejones64
Dan
MN
Bronco 2-dr Black Diamond
Currently have a Rockpals 300w solar battery. Will be getting another solar battery and solar panel(s) for other items.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Apparently the 12v socket is not constant hot. I added a second one that is.
The fridge I have will shut off if the voltage drops too low instead of killing the battery. So far if I keep it plugged in all day at 38F and unplug overnight I'll wake up to it at about 50F.
I have a 66ah lead acid battery in my camper. It has plenty of capacity to keep that same fridge powered overnight (that's accounting for the effective 50% usable capacity of leaf acid). A 50ah lifepo4 would be even better and they're pretty cheap.
CptSamFalcon
Sam
Kent, WA
2021 Bronco 4dr BD, 2021 Kawasaki KLX300
I'm running an EcoFlow River Pro battery. I really value small size and fast charge time and it has been perfect for my needs. Being able to add another battery module to it later on if needed is also good.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Were using a Bluetti portable power pack to power our ARB Zero 47qt. fridge.
The Bluetti powers the fridge and we have the Bluetti plugged into the rear cig port, so that it charges while we drive.
When the truck is sitting at the shop we tend to plug the Bluetti into regular 120V power to keep the battery charged.
We can go about 3 days before the Bluetti needs to be recharged
BC overlanding
IN/KY area
I had the same setup but with a Jackery. I had the Jackery plugged into the rear port and fridge into the Jackery. I have been having a problem with the fridge shutting down when the rear port times out after 2hours. Have you ever had this issue?
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
The rear port in the cargo area only stays hot for 45 minutes. If your PPS is fully charged, it should be lasting longer than an additional 1hr and 15min before the fridge cuts off.
Noremac
East Coast Florida
2021 Bronco Badlands Sasquatch
You can disable the timer in forscan. I have mine 100% off. it will shut off when the battery gets down to 12.4v or so, plenty to get the bronco started and get recharged
Beach_Bum
St. Augustine, FL
I was stating the factory setting. Most will not make modifications via ForScan.
RHeinz
Ric
Houston, TX
Ford Bronco Powering your fridge/freezer? IMG_0291
This Bluetti power bank has about a 500 watt hour useable capacity, so maybe 12 hours of fridge time in a hot climate. Plugged into the rear outlet to charge while driving. Mounted out of the way for sleeping in the back of the Bronco.
I also carry 2 X 200 watt solar panels when camping and another Bluetti AC180, which has about 900 useable watt hours and charges at about 200 watts off the 400 watt AC outlet in the Bronco, again while driving.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Well your fridge should not turn off if it's plugged into the jackery, unless the jackery is running out of battery power.
