- First Name
- Mitch
- Joined
- Mar 11, 2021
- Threads
- 28
- Messages
- 2,364
- Reaction score
- 4,112
- Location
- Cape Cod, MA, formerly Flagstaff, AZ
- Vehicle(s)
- 21 2 Door Badlands 6MT - Sold, 01 Expedition, 24 Tesla Y, 24 F-150 Lightning
- Your Bronco Model
- Badlands
I installed the Kicker Key 200.4 amp using the plugnplaykits.com harness on Sunday night, no other audio mods. The harness I bought has outputs for adding another amp later. All in about $475 for amp and harness. I ran the DSP setup and the sound is certainly better than stock with a few observations. The front stage is very forward and centered, a good thing, the vocals are much tighter than they were. The rear speakers, even with the amp and DSP, sound like a 1980’s set of Walkman speakers. Leave the gains set at zero or it’s ungodly loud and could blow a speaker. Overall it’s much better, but still like comparing a kick in the knee to a kick in the balls. I did bump the bass and treble adjustments back up on the head unit while testing which helped, I had zeroed them out before running the DSP.
The plans forward are as follows:
Remove rear speaker pods entirely. They add nothing to the sound and are in the way when loading cargo or accessing my ARB fridge. I ran no rear speakers on my last two audio builds.
Replace the front kick panel speakers and dash speakers with a decent quality component set, maybe JL Audio C2-650 ($329) or AudioFrog GS separates ($550)
Rewire the harness to biamp the front components with active crossovers in the Kicker 200.4 amp. No point in wasting the power on missing rear speakers.
Add the Kicker 500.1 amp ($269)
Add some version of subwoofer box in the stock B&O location
Option B would be the same as above except switch to a 5 channel Audiocontrol amp kit 50 from plugandplaykits ($970).
That is as far as I’m willing to go from here. If I wait for JL Audio to make a stealthbox it will probably be $1000. I could try to find a stock B&O enclosure and upgrade the sub, probably $300-350. SRQ makes a good looking hidden sub for $625. The SRQ is probably a good compromise since it’s better than the B&O plastic enclosure and has a better woofer.
