Plug and play speaker upgrade?
Broncobreath
Patrick
Hamburg ny
2022 bronco
I have a 2 door badlands with the basic speakers. Is there a simple plug and play speaker system for better sound?
Ksjrb03
Tx
F250
I hate to be that guy, but there are literally hundreds of posts discussing the options, and great diy write ups. Right here in the audio sub forum you posted in. Browse away.
Broncobreath
Broncobreath
Patrick
Hamburg ny
2022 bronco
you are correct, but most of them are custom installations with subwoofers. I’m looking for a basic speaker install that would fit in the factory holes and mounts
UniBronc
Ryan
Lake Wissota Wi
11 F550, 12 F550, 13 F250
I'm with you on that. Have a base as well & would like a little better sound.
mcinfantry
Lee
Louisiana
Badlands 2 door
There’s literally a hundred posts on a plug and play option for better sound
1) using forscan
2) changing speakers
3) adding only an amp
4) adding an amp and changing speakers
5) adding a soundbar
6) adding a subwoofer
7) combinations of these
it boils down to what you wasn’t to spend vs outcome you want
Cl1ckst3r
Joshua
Minneapolis
Ford Focus ST
I did a pretty basic upgrade. I replaced all my 4 inch speaks with Powerbass 2xl
https://powerbassusa.com/us/en/products/mobile-audio/2xl-403-4-full-range/
I did add a down-firing 12 inch subwoofer ( JL Audio 12T3-D8 powered by Powerbass XL-2305MX).
I am very happy with the results. I can't turn up the volume past 25 or it starts to hurt my ears...even with the top down going 60MPH and the subwoofer volume rarely goes past 25%....maybe I could have gotten away with an 8 or 10inch woofer. Oh well. ;-)
The stock kick panel speakers are mid-woofers from the factory...so not point in putting coaxials there unless you want to re-wire but I think most people say a tweeter in the footwell is pointless. I left these stock.
My local shop recommend this Powerbass mid-woofer if I wanted to upgrade that speaker.
https://powerbassusa.com/us/en/products/mobile-audio/4xl-65T-65-mid-range/
I was offered the option to add a dedicated amp for the cabin speakers but I don't think I need it.
For the stock six speaker system, most people complain that the highs are muffled and the lows are minimal. This upgrade fixed both of those issues IMHO.
I could've spent a lot more money on another amp, name brand speakers, and a creative placement of the subwoofer (tailgate mount or B&O mount location) but these speakers got high marks for the price and another forum member convinced me to save the money and just do the down-firing subwoofer...I can always spend more money later.
Broncobreath
Broncobreath
Patrick
Hamburg ny
2022 bronco
Thank you for actually giving me a real answer. Everything I’ve been reading, there are no speakers that actually directly plug-in. You’d have to get an aftermarket fitting, true?
Duke460
Earle
Southeast Wisconsin
Go to Crutchfield and type in your vehicle. They will list replacement speakers that fit and provide the plug in wiring adapters.
Hoel and Plug&Play both offer plug and play wiring harness's if you want to add subs.
As others have said there are 100's of posts and videos detailing how to do this..
Blackcat
South Carolina
2022 FORD BRONCO BASE 2 DOOR M/T
I have PB speakers in my F150 and love them. Glad I saw this post as I was getting ready to call PB to see what speakers they'd recommend for my Base build.
RC Bronco
Kansas
I first started with replacing the dash speakers with 4" Kicker 47KSC404 w/ 300 hz bass blockers
Then I changed out the kick panel speakers to 6.75" Kicker 47KSC6704's
Next step was adding a Kicker Key 200.4 amplifier with a Plug n Play harness plus the Kicker tuning process
Last night I (almost) finished installing a Kicker 11HS8 hideaway in the factory sub location, also with a Plug n Play wiring harness - had a bit more trouble with this install than I did when I installed another 11HS8 in my '97 Tracker, but I think I've gotten it figured out now
My next step is probably going to be waiting for Mabett to release his rear speaker pod replacements so that I can put 6.5" speakers back there
Beyond this, I'll likely look into some of the ForScan changes to further improve the sound system, but that's not too high on my list at the moment
jacknifetoaswan
JR
Charleston, SC
2016 Mustang GT/PP
My plan, which will be executed this weekend:
1 - Focal ACX-100 4" speakers in the dash and rear pods.
2 - Focal RCX-165 6.5" speakers in the kick panels.
3 - Metra S-6600 6.5" speaker adapters to install the kick panel speakers.
4 - Speaker harness adapters with 300 Hz bass blockers for the 4" speakers and adapters without bass blockers for the kick panel speakers, from fast-daddy on eBay (I think he's a member here).
5 - Two Forscan changes to the ACM. Change 727-01-01 to xx00 xxxx xxxx, and 727-01-02 to 0900 xxxx xxxx.
6 - ?
7 - Profit.
JR
fitterhappier
Adam
Round Rock TX
2022 Ford Bronco
You are correct - you will need adaptors for any aftermarket speaker. I got mine from Saleen - they were pricey, but allowed for true plug/play and Saleen is just down the street from my house :)
There are other options as well - Crutchfield actually has the 6.5 adaptors; it's the adaptors for the 4" speakers that you may have to go elsewhere for. Not sure if that's changed (I got mine back in April). Edit - just checked the Crutchfield site - they do NOT have adaptors available for the dash and rear pod speakers; Saleen, the Amazon guy (should be able to find him via search) and splicing will be your best bet.
Black_Stallion13
Cincinnati
Tacoma
I just replaced all 6 of mine with Kicker CS speakers. If you order from crutchfield, you will get everything you need for the kick panel speakers for free (adapters and wiring harnesses) I also ordered two sets of the new 4" speaker wiring harnesses from plug n play kits so I didn't have to do any splicing for the front and rear. All in it was like $230 I think. Sound is deff a bit better than stock.
Broncobreath
Broncobreath
Patrick
Hamburg ny
2022 bronco
Thank you, great advise
