Perimeter Alarm Plus Observations after install
LanceOH
Ohio
2024 Bronco OSX Sasquatch
I had a tech look at mine and said it was functioning as intended. You cant see mine in daylight but can at night. If I had to do it over I wouldn't have gotten the LED.
Lifeliberty
Moonbeam👀
Columbus, OH
Ive never had an issue seeing the light. Perhaps find someone else you can compare the perimeter light with in your area. For the cost, I don't find any reason to not install it. I mounted mine in the passenger dash speaker grill. I can normally see it when I'm walking to my car from work
LanceOH
Ohio
I appreciate that, yeah I would like to see anyone in daylight . I have mine mounted in same spot, btw.
EOD98
Las Vegas
2025 Bronco Badlands Sasquatch
It’s not bright at all. I have to look hard unless it’s dark out and no lighting. Installed mine in the passenger side dash speaker grill as well. Could maybe wire in a different bulb?
LanceOH
Ohio
Appreciate the input, sounds like mine. I have seen 2 different led types. The newer version is what I have and appears to be a down grade.
EOD98
Las Vegas
I’m gonna try and switch out the bulb for something aftermarket. Will report back
