Parasitic draw
Status
Not open for further replies.
BT!
Bud
tallahassee
bronco
  • Thread starter
  • Banned
  • #1
2023 4k miles. Parasitic draw kills battery in 48 hours with door locked and key away from vehicle. New battery did not resolve issue. No switched accecories or charging cords connected. I have heard of lights cycling on and off, causing this. Any other experience ?
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
any aftermarket accessories or hidden dealer installed tracking/remote kill switch devices?
BT!
Bud
tallahassee
bronco
  • Thread starter
  • Banned
  • #3
Nope.
PSUTE
Western Maryland
Sierra
Must be a short somewhere before it hits the computer or on a circuit that does not require computer. Otherwise it would leave you enough of a charge to start...
Ford Bronco Parasitic draw 646851a3-0c1a-461a-a46a-8c0f223859a0-
BT!
Bud
tallahassee
bronco
  • Thread starter
  • Banned
  • #7
Yea thats why lights make sense. Itdoes seem to go into deep sleep mode but something is off. Hopefully dealer can fugure it out next month but im not holding my breath as if its not in the computer real trouble shooting skills seem limited.
Lcubed
l
UsA
time to check all your ground connections are tight.
BT!
Bud
tallahassee
bronco
  • Thread starter
  • Banned
  • #9
Probably a good place to start. Anyone have a diagram of the electrical system or ground contacts. Looking to go in armed to dealer with as much information as possible to avoid stealership fuckry.
chtucker
Kirkland, WA
FJ Cruiser
Is this the same vehicle/poster from FB that wouldn't say what mods are installed? They "say" that there are no switched accessories, but they got all upset when someone challenged them asking what mods were done.
Are there any modifications???
BT!
Bud
tallahassee
bronco
Sure is sparky, I said it there and I said it here NO MODICIFATIONS NO SWITCHED ACCESSORIES. you menitoned that accessories would not have to be switched to killl the battery which is unrelated and indicates you dont understand how circuits work..
Do you have something helpful to offer other than to place blame on the person asking for assistance ?
chtucker
Kirkland, WA
FJ Cruiser
No but I manage a fleet of over 1200 vehicles and all of their added in car technology. 99..999% of the time a parasitic draw is the aftermarket accessory added.
So what you are saying is that your vehicle is 100% stock? NOTHING added?
The way to identify a parasitic draw is to take a multi-meter and measure the current draw when the vehicle is off/shut down. If you see any current flow, keep pulling fuses till it stops. You have then identified the circuit. A wiring diagram won't help. You armed with a schematic won't help with a service adviser (who are not techs). Your comment about "ground contacts" is bizarre. The whole dam vehicle is a ground with multiple connection points. The only way to find current flow is using the positive side/fuses. There will be MULTIPLE ground paths for circuits to complete.
I don't physically do automotive electrical troubleshooting any more, but I teach people how to do it.
Buckethead
Denver, CO
‘21 Exp ST, ‘22 Base 2dr & ‘23 2dr Badlands
Did the issue suddenly start or was it always present since new? I.e. maybe you only recently started leaving parked 48hrs and/or only driving it very short distances and noticed the issue. Also - you stated “no switched accessories” but any powered aftermarket accessories? Not trolling here, just caught off guard but the “switched” specificity.
Could be the alternator isn’t working but that would be surprising - auto zone/oriely’s/etc… can check that for free. There’s always a parasitic draw on the battery but for it to go flat in 48hrs is pretty darn fast If your driving it and your alternator is working.
Mlarv
TN
The way to identify a parasitic draw is to take a multi-meter and measure the current draw when the vehicle is off/shut down. If you see any current flow, keep pulling fuses till it stops. You have then identified the circuit. .
This is the best way to find it. You can also use an AMP clamp, but it might not be as accurate.
chtucker
Kirkland, WA
FJ Cruiser
Correct, a clamp on ammeter is super sensitive, any movement seems to make the numbers jump around. interrupting the circuit with an inline high quality multi-meter seems to work best.
Status
