Overlanding Suspension
Inlinejohn
WA
Several
Opinions on the best coilover upgrade from Sasquatch to handle weight of gear, roof top tent, long on/off road trips, washboard roads, and potentially pulling an Overlanding trailer (Patriot X1N)
Coilover Options I’m thinking about:
4WP adjustable
KING w/ adjustable reservoir
Fabtech adjustable w/ reservoir
Others?
Don’t want to break the bank. All the above are in the $4K range
JBowles
Jordan
Ozark, MO
Ram 2500
I'd keep an eye on the Old Man Emu stuff they know that game pretty well and really keep the vehicle dynamics and larger loads in mind.
We_Love_Tacos
www.bronco6g.com
2021 Ford Bronco First Edition 2Dr Lightning Blue
My first choice and what I have awaiting install are Kings for sure. once you’ve had them you will understand.
My second choice would still be Kings. 🤣😂
Third, probably OME from what I’ve heard and researched.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Everything is to new still, I have a eye on old emu as it definite upgrade from the non-sas shocks. If I was paying I would want King, just for the fact that they are serviceable and you can get just about any spring rate.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Check ARB-USAs OME page. OME has multiple spring choices for the heavier loads of overlanding. They don’t yet list shock travel specs.
https://arbusa.com/ford-bronco/old-man-emu-4x4-suspension/
We need a guinea pig, I went through this with my FZJ80 land cruiser. Going to take someone not being happy and switching between the different springs with lots of pictures.
I bought 5 sets of springs before I was happy with my landcruiser. I had to switch to another brand for dual rate springs.
RainbowStix
A Big Island
Toyota Tacoma
Definitely think about OME with your setup as they have more options for weight. Could also just get compression adjusters but not from the high end brands for the following reasons..
You don’t want fox/king/Radflo as these gear toward faster speed stuff, so are valved and made as such (monotube, spherical bearings, etc). With overlanding, you also want to think about corrosion especially if you’re gonna be doing water and mud crossings. With any bare metal shock like the above mentioned, the steel parts are usually plated with something else that eventually wears off. Nothing beats a good paint job.
lastly, the 4wp coilovers are hot garbage. Every owner I’ve talked to seems to agree on that.
Silver-Bolt
Eureka, MT
Don't forget Icon.
Inlinejohn
Inlinejohn
WA
Several
I’m holding out for OME BP-51.
RainbowStix
A Big Island
Toyota Tacoma
Not the best option for your application believe it or not. Also not the best shock in general but to each their own… you’d be better off with one of the fox/king brands. I was talking about their nitrocharger line :)
Tcarp1
Travis
Newcastle, CA
2021 2 Door Badlands
I went with radflos. Very happy with performance so far. I can adjust them to firmer valving if needed. Will be heading to Rubicon next weekend and see how they do in the rocks.
Ford Bronco Overlanding Suspension 20220430_185610
Ford Bronco Overlanding Suspension 20220430_174218
