Oil change via extraction method vs. drain plug
FunForAll
WA
Bronco, 2 F-150s, Explorer, Mustang
First oil change this past weekend at 3,000 miles on my 2.7L. Didn't realize this had already been discussed so tried the extraction method (since this is my first topside oil filter). After extracting, I also drained the remaining oil at the drain plug and got another ~5oz.
Ford Bronco Oil change via extraction method vs. drain plug 1661370336600
I find this ironic that an engine with a full drain filter also has a "Flat Foot Crank" to prime the fresh oil as demonstrated in this IAG Performance video:
Am I missing something?
Brockdog12
NTX
2022 Explorer ST-Line
I always used the drain plug on my 2.7L F150 and let it drain for at least 25-30 minutes per the TBS those engines had.
BulldogBear
BulldogBear
Scottsdale
2021 Ford Bronco Badlands, 2000 Mercedes-Benz G500
So did you get most of the oil out via extraction/suction and only 5oz came out of the bottom?
FunForAll
WA
FunForAll
WA
BulldogBear
BulldogBear
Scottsdale
Yes, that's correct.
what diameter tubing did you put down the dipstick tube?
I installed the Ronin drain plug during my first oil change and didn't bother trying the suction method, but if there's only 5 oz left, I might revert back to extraction and the drain the remnants afterward - less containers to transfer used oil to and from...
swooshdave
Portland, Oregon
Mustang
FunForAll
WA
6mm tubing
Also worth noting. I filled with 6qts, have the original dip stick and my oil level is perfectly at the top mark (hole).
FunForAll
WA
JBlanco
Julio
Charlotte NC
Patkachu
Patrick
New Jersey
Audi, Bronco
I am also prepping to go with the extraction method and then doing the ronin drain for the rest. I don’t want to make a mess. Thanks for confirming it works.
speedup
Dallas, TX
2023 Bronco Outer Banks
Old thread, but why would you extract the oil through the dipstick tube and not through opening where you fill the oil?
Haelous
US
2016 Mustang GT, 2023 Bronco Wildtrak
How would the extraction tube get through the engine to the bottom of the oil pan?
