Oil change light between regular maintenance?
LSW
L
North
'24 Bronco Wildtrak
Mine seems to drop faster in the winter. Could be due to a few factors: oil doesn't get as warm on short trips, relative humidity is higher so it's more likely to collect water, I'm more likely to drive a shorter distance because I don't want to walk in the cold, it doesn't heat soak as badly so I'm more likely to hammer on it once it warms up, etc. I can't remember where I saw it, but I've heard the oil life algorithm is actually pretty sophisticated.
If you went out and checked it right now and counted down mileage from your last oil change, or % into 365 days, what does it say? I am in a pretty cold place and do plenty of sub zero starts, never seems to go down faster.
I believe some oil life algorithms can be complicated, I just don’t think the one in the Bronco or most other Fords is.
Combustion_King
Derek
MA
Yes
i change my oil, empty my catch can and rotate my tires when the counter says 30% life. that on average is 6500k or so. When i reset, only option is reset oil, hold to reset.
LSW
L
North
'24 Bronco Wildtrak
We have to be careful with these oil threads. First, they can get awfully intense--such an interesting thing to arouse strong passions. Second, there's been so many threads on oil.
That said, I didn't know the oil indicator was set for 1 year/10K miles. Now I hear it also monitors the oil's chemical status. So which is? Quantity (time + mileage) or quality (analysis) or both?
Also, any difference between regular oils and synthetic in the oil change display?
I can pretty much promise the Bronco isn’t doing any kind of chemical analysis on the oil to feed to the oil life indicator. That would be awesome if it was true. It counts down days and miles from last reset, divides those numbers by 365 and 10,000 respectively, subtracts from 100 and displays the smaller of the two values as the %.
If you drive less in winter (many do) it will seem to go down faster compared to miles driven because it starts to use calendar time.
CalvinT
Calvin
Phoenix, AZ
I do 3000 miles because I'm severe duty by definition which is stop and go short trips probably overkill
Years ago a local radio station had both Ford and GM reps on the air. It was easy because they both had proving grounds here in Arizona. A caller asked about stop and go drving in Phoenix summers. The reps said they test for it and that they considered stop and go driving in Phoenix summers to be normal use.
23OBX2.7
AB Canada
2023 Bronco
I just like getting it up on hoist and changing oil....looking everything over plus since I'm on metric it 5000KM a nice round number VS 8000 / 5000 miles or 10,000 which is too much IMO.
I drive it hard the turbos work hard lots of short cut and thrust trips so I treat them well with fresh Pennzoil Euro Synthetic 5W40 every 5000, eventhoug I do proper warm up and 2 min cool down at idle.
I should just switch to 10000 km / 8000 miles since it's got 6.5 quarts...
Both. Sorta. It infers oil quality, it doesn't have any chemical sensors. But looking at time and temperature and power it can make some educated guesses. 10k ~seems~ to be the default mileage, and factors that can accelerate oil degredation cut down from that. And if it sets for 365 days, it'll pop regardless of miles.
There's no way to tell the computer you have synthetic or some other exotic blend or different weight. I think it just assumes whatever was loaded from the factory - default Motorcraft Blend in the factory weight and specification.
The F150 folks claim that towing will cause the oil life to drop faster. I know folks where it gets cold can see it go down faster in the winter than the summer. I know my service trucks that sit idling for hours will go faster than the ones that don't. My wife's Sport that does a lot of short trips will count down much faster than my Bronco, that rarely sees trips of less than an hour.
I couldn't find the engineering article but I found a couple of ok ones. I wish I could find that engineer one because he went into a lot of the reasons behind things -- these articles are more high level/consumerish. I'll keep digging.
https://www.lombardfordprotect.com/delving-deeper/oil-life-monitor.cfm
https://www.autocentricrepair.com/h...il change sensor works,you need an oil change.
Poppavein
Redmond, WA
Harleys, Ducatis, 2024 Bronco
From Grok (my engine):
Ford’s Intelligent Oil-Life Monitor (IOLM) in the 2024 Bronco 2.3L
The 2024 Ford Bronco with the 2.3L EcoBoost engine uses Ford’s Intelligent Oil-Life Monitor (IOLM) system to determine oil change intervals. This isn’t a fixed mileage schedule—it’s a smart, algorithm-driven tool that calculates remaining oil life (displayed as a percentage from 100% to 0%) based on real-world usage. It helps optimize engine protection while reducing unnecessary changes, tailored to your driving. Here’s how it works:
How the Algorithm Functions
The IOLM is a software-based system integrated into the vehicle’s onboard computer (Powertrain Control Module). It uses an advanced algorithm to monitor and analyze multiple data points from engine sensors, then decrements the oil life percentage accordingly. Key inputs include:
• Driving habits: Aggressive acceleration, frequent short trips, or stop-and-go traffic (which increases engine wear and oil contamination).
• Operating conditions: Extreme temperatures (hot or cold starts), high humidity, dusty/off-road environments, or low-speed driving.
• Engine performance metrics: Engine revolutions (RPM), run time, idling duration, number of cold/hot starts, and fuel dilution (common in turbocharged engines like the 2.3L).
• Load factors: Towing, off-roading, or heavy loads that stress the oil.
• Time-based decay: Even if mileage is low, oil degrades over time due to oxidation and moisture buildup (e.g., up to 1 year max interval).
The algorithm processes this data continuously during drives, applying a proprietary Ford formula to estimate degradation. It starts at 100% after an oil change/reset and counts down—faster under “severe” conditions (e.g., off-roading in the Bronco) and slower for “normal” highway driving. Unlike basic timers, it doesn’t rely on a single sensor (like oil quality probes in some brands) but on a holistic model calibrated for synthetic blend oils like the Motorcraft SAE 5W-30 recommended for the 2.3L.
• Normal conditions: Expect 7,500–10,000 miles (or ~1 year).
• Severe conditions (e.g., frequent towing, extreme temps, or off-road use): 3,000–5,000 miles (or sooner).
• First oil change: Often around 5,000–10,000 miles post-break-in, but follow the IOLM.
If equipped with FordPass Connect (standard on most 2024 Broncos), it syncs data to the FordPass app for remote monitoring, including time/distance estimates.
Alerts and Display
• View oil life % via the instrument cluster: Go to Settings > Vehicle > Oil Life (or similar path—check your screen).
• Warnings:
â—¦ Change Engine Oil Soon (at ~5% life): Schedule service within 500 miles or 2 weeks.
â—¦ Oil Change Required (at 0%): Change immediately to avoid engine damage.
• Notifications appear on the dash and (if connected) push alerts via FordPass.
Resetting After an Oil Change
After servicing (use 6.0 quarts of Motorcraft 5W-30 synthetic blend and a Motorcraft FL-500S filter for the 2.3L), reset manually:
1 Turn ignition to ON (press Start button without brake).
2 Navigate to Settings > Vehicle > Oil Life on the cluster.
3 Select Hold OK to Reset (or similar—hold the OK button for ~2 seconds until it confirms 100%).
4 Drive one full cycle (>1 mile) for the system to recalibrate.
If it doesn’t reset properly, a dealer scan tool can do it. Note: Always reset after changes to avoid false alerts.
Tips for Your 2024 Bronco 2.3L
• Turbo-specific care: The 2.3L EcoBoost runs hot, so the IOLM accounts for turbo oil demands—stick to Ford-spec oil to maintain warranty (5 years/60,000 miles).
• Off-road adjustment: Broncos see “severe” use often; the algorithm will shorten intervals automatically.
• Manual override: If you prefer fixed schedules, ignore IOLM and follow the owner’s manual (10,000-mile multiples for basics), but Ford recommends trusting the system.
• For exact details, download the 2024 Bronco Owner’s Manual via Ford’s site or app, or visit a dealer for a free IOLM check.
This system ensures your Bronco’s 300-hp turbo stays protected without over-servicing—reliable for most owners, though some change every 5,000 miles for peace of mind. If your IOLM seems off, it could be a sensor glitch; get it diagnosed. Safe wheeling!
LSW
L
North
'24 Bronco Wildtrak
I can tell you I’ve done about a dozen oil changes on two different 2.7 broncos and the “IOLM” has never done anything but countdown from 1 year or 10k miles. I am skeptical that it does much else. If it does, it must take egregious abuse like sustained oil temps over ~250F or sustained RPM over 4000 under load. Could it be different for other Fords? Sure. I think in the case of Bronco they are using flowery language to account for short trips with the 1 year calendar interval.
I do a trip calculator for my oil changes. On the last round one Bronco had 250 hours of run time to hit 5k miles with a lot of idling (overnight camping with engine idling periodically for heat). The other took ~140 hours almost all highway with no idling to hit 5k. They both had exactly 50% oil life remaining. It has been this way every time I’ve changed the oil, so whatever other variables it looks at, if any, apparently aren’t triggered by a lot of idling or cold starts, or if they are it must take egregious amounts.
