OEM MUDFLAPS WITH OEM RUNNING BOARDS
bronco 1876
Jack
Boston
Hey - This might be dumb, but has anyone installed the OEM mudflaps front and rear with the OEM running boards already installed? I have seen pictures of them with the running boards, but I want to make sure they can go together. I have a 2024 OBX.
aermtr
Don
Portland Or
broflaps.etsy.com
'20 GT500 CFTP, 65 Cobra and '23 Badlands 2.3 7MT
We use spacers because the factory steps encroach into the wheel well. So if they don’t fit, you might need 1/2 to 3/4 inch spacers for fit.
broflaps.com
Ford Bronco OEM MUDFLAPS WITH OEM RUNNING BOARDS IMG_4527
box986
Paul
NNJ/NEPA
23 GX460 22 Sport BB, 03 Caddy EXT PU, 96 Lincoln MarkVIII, 92 Toyota PU 4x4
Rockblokz up front with OEM running board
Luckylat
RI
1999 Expedition, 2013 VW Wagon, 2023 Wildtrak
I ordered a kit from Mabett for all four flaps, but only installed the front as the front wheels kick up a lot of sand, mud and rocks onto the side of the doors, etc., Work well and simple to install with the OEM running boards. Worth the investment and time to install.
I drive mostly road, sand at the beaches , dirt roads for camping/hiking, snow. Not scaling any major rocks. There are mud flaps that are set up to remove for serious rocky trails if that is your desire.
Mabett -Amazon Link: https://www.amazon.com/s?k=mabett+m...b3fb5e&tag=googhydr-20&ref=pd_sl_5qas1a6oe0_e
Ford Bronco OEM MUDFLAPS WITH OEM RUNNING BOARDS Bronco Mud Flaps_1962 (2)
ejpaul1
Pacific northwest
ther gatorz ones are like 500 bucks, im cheap, i bought the redrocks, which were too short and do nothing, but then bought CHEAP ones from oriely auto parts and bolted them on. if you dont put these on, you will chip the paint on the front doors. THey do scrape on rocks when rock crawling but I dont mind that. I can send a pic of this option if you like.
Eldowerks
Minnesota
Bronco ‘24
Mabbets fit well with factory running boards and look OEM. You can buy them with or without the graphic.
They work well for keeping mud and ice off of the doors which in Minnesota winters can get all the way up to the door handles.
DemonGT
Dan
Wisconsin
2022 Badlands
How close to the running boards are the flaps?
Gunther
2023 Ford bronco Raptor
Yours look really nice
Eldowerks
Minnesota
Bronco ‘24
The Mabett front flaps perfectly touch the front of the factory running boards.
Ford Bronco OEM MUDFLAPS WITH OEM RUNNING BOARDS IMG_5972
In fact, the Mabett flaps were shipped with a sheet of adhesive-backed foam rubber that pieces can be cut from to provide a cushion/shield between the flaps and the fronts of the running boards.
FWIW, the Mabett front flaps also just kiss the factory rock sliders.
Ford Bronco OEM MUDFLAPS WITH OEM RUNNING BOARDS IMG_6623
DemonGT
Dan
Wisconsin
2022 Badlands
Which pinch weld covers did you get?
Eldowerks
Minnesota
Bronco ‘24
@DemonGT Broaddict Aluminum Pinch Weld Covers. They work with the factory running boards, but not enough clearance with factory rock sliders.
