Noise while driving down the expressway
Bigfoot bronco
Mario lorenzon
lifewithadv.com
2023 Badlands
It started happening 2 to 3 weeks ago it only happens at high speeds but only last a couple of seconds
Montana Bronco
Montana
Chevy
They started happening 2 to 3 weeks ago started driving down the expressway and this noise started it only happens when I am moving down the expressway
Expressway ? Sounds a lot like mall crawling. The real test of a Bronco is on dirt while in 4LO. Try that and report back on what noises you hear.
Bigfoot bronco
Mario lorenzon
lifewithadv.com
2023 Badlands
She definitely is not a mall crawler just got back from Silverlake, but besides the point, I’m just trying to figure it out, bud.
Shazamalingo
West
2022 OBX SAS
Is the car bouncing or on flat ground?
Dan-O
Dan
Fountain Hills, AZ
Do you happen to have roof rack? If so could something be loose enough to vibrate at higher speed. Or possibly the cowling at bottom of windshield? Ya that would drive me crazy. Is it always happening at about the same speed, I know u mentioned expressway.
dejones64
Dan
MN
Bronco 2-dr Black Diamond
Screw loose in the armor underneath, something vibrating at high speeds...
Nc211
Washington DC
Sounds like a loose heat shield perhaps around the transmission / transfer case? Maybe the wind is letting it brush up against a driveshaft or knuckle? Or maybe loose side step bolt? It sounds like something light medal to me, not a heavy thunk thunk, but a ting ting.
BadlandsA51
Craig
Kansas
23 Badlands, Sasquatch, Lux Pkg, 72 Ranchero GT
Sounds like a suspension, body mount, or crossmember bolt causing the noise as you drive over irregularities in the road. Get a breaker bar and some sockets and check all the bolts you can get to.
