No manual cruise control!
bmclain
Albuquerque, NM
2013 Ford Explorer, 2021 Ford Bronco Badlands
I'll start this off with part of this is my fault. I have the adaptive cruise control module blocked, and might have one of my parking sensors messed up. More on that later. But even with these, I should be able to go into setup and switch to normal cruise control, but its acting like it will only do adaptive. Here's a pic showing its set to normal and when I try to set cruise it throws an error.
Ford Bronco No manual cruise control! 20220801_141332
Anyone have any idea how to fix this, or have seen it? I'm currently in Maine and have to drive back to Missouri in a few days. It worked most of the way here, just stopped around new jersey. Didnt realize how much I would miss cruise control until its gone.
Extra info: Added winch to bumper causing acc and parking sensor relocation, then added prerunner bar which now blocks relocated acc. I'm going to put the acc back when I get home.
zombie
New Brunswick, Canada
It specifically says adaptive cruise isn't available, so regardless of whether you choose normal cruise control or not, it should just be plain old fashioned cruise control.
Did you actually try to test it?
bmclain
bmclain
Albuquerque, NM
Thats the error I get when I try to engage the normal cruise control.
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
you should be able to turn of ACC in the touchscreen options. I don't see where you attempted that. I could be wrong though, it happens....I'm old
jehines3
Easton, MD
Lexus RX350L, Chevrolet Silverado, Lincoln MKC
Are the emergency braking functions off as well?
bmclain
bmclain
Albuquerque, NM
Thats the screen on the right. I have it on normal not adaptive.
bmclain
bmclain
Albuquerque, NM
zombie
I dunno, try the old "remove the cable from the negative battery terminal for a bit" trick?
Barring that, seems like something is wrong beyond that blocked sensor. You should definitely be able to use "normal" cruise control.
Jgiss
Jake
Las Vegas
2022 Bronco
running into the same issue. My ACC is unplugged currently but unable to use cruise control as normal. Super weird. Any fix to it?
bmclain
bmclain
Albuquerque, NM
Never found a resolution. After unblocking the ACC module and driving a lot of miles, it cleared the error. I do still sometimes get the blocked message, but typically clears quick enough that I can still use the non-adaptive cruise. I wasn't sure if there was a separate fuse for ACC. Was thinking about trying to pull it.
GrizzlyPete
2023 Ford Bronco
Apologies for jumping on an old thread, but I just bought a 2023 Badlands LUX that had an aftermarket bumper w/winch installed. Within 5 miles I started getting this error and can’t get it to clear. The person that did the mod just zip-tied the sensor to the grill. I bought and mounted it to a relocation bracket, but it didn’t solve the problem. Did you go back to the factory bumper and sensor location? Did you do anything special to clear the error?
Strizzo
Houston, Tx
Lexus GX460, 1966 Mustang Convertible, Jeep Wrangler TJ
you’ll probably need to do a recalibration of the acc sensor, which can be done through forscan. You could also disable acc with forscan so the system isn’t looking for the acc sensor.
rtaylor
R
ID
19Raptor, 22Bronco
Re-enable ACC and braking in menu. The sensor alignment is critical. The error will continue to be reported if the sensor is incorrectly aligned.
It needs to be within +/-3degrees horizontal (forscan can check horizontal alignment using "calibration", but use that as last resort because high risk). Use a yardstick along front of bronco to compare.
The sensor is supposed to be 90.0 degrees vertical (straight ahead), but since relocation bracket is higher it will probably work better pointed slightly downward 1.5-2 degrees. You have to measure the non-raised part of the sensor using digital level (or perhaps phone app). In my case, 90 degrees resulted in errors and flakey ACC, but 1.5 down works well.
