Ironiguana
They feature a dual-color DRL. That means you don't have to select white or amber DRL when you order them, both colors are built in. It's easy to change colors as well. There is a single wire connector on each side. Plug it in, you've got white DRL. Unplug it, you've got amber DRL. Real simple. No need to remove the headlights to change the color of your DRL.
Do you think an aux switch could be used to switch between white and amber?
popo_patty
Caleb
Sacramento
2021 Bronco/1996 Jeep XJ/1957 FC-150
Really really like these!
Razorback
Bill
Dallas
Lincoln MKX
Do the drl stay on in park? I'm assuming they must unless you had the emergency break on in the pictures. I hate that oem turn off in park unless the headlights are on.
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
Nice!! I have to get these.
GloNDark
Reno NV
1973 Bronco Ranger & 2021 Bronco First Edition
Those look sweet!! i'd be interested to see a beam pattern comparison with stock headlights.
jalawson
TX
ā€˜22 Bronco, ā€˜17 F150
Ya’ll did a great job comparing OEM and Morimoto brightness and beam pattern. Could talk do something similar for these?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
I mean technically you COULD if you install a relay that doesn't provide power. The relay would just make/break the circuit for the light. But it's not necessary. You can just plug or unplug the connector on the back of the light if you want to get a different DRL color. It's accessible WITHOUT removing the headlight. Pop the hood, disconnect/connect it, close the hood. Takes longer to open the hood then to disconnect/connect the wire on the back of the headlight.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Depends if you wire in the optional DRL harness. Without the DRL harness the DRL functions just like your normal amber indicators on the front. But with the DRL harness installed (it just connects to the fuse panel with the included fuse tap) they'll stay on all the time (which is what most folks want).
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
We will, when we can. Again we were sent a few of these to try out and give some feedback on and take some photos. We are not listing them for sale until the official release date and we're also not publishing side by sides until Form gives us the go ahead for a pre-release "shootout" or they are released.
They are not even on the Form website but with SEMA kicking off this week they are out in the open. So whatever you can see at SEMA is what we're basically sharing for now
HorizonHunter
Joseph
Chapel Hill, NC
Grand Cherokee Trailhawk
First headlight swap I'm interested in
jalawson
TX
Gotcha. Thank you! I misunderstood the initial post and thought the official release was going to happen at SEMA.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Well they are announced at SEMA. But not available for purchase yet
67BroncoG1
Ron
CA
'22 2D Squatch, '67 Bronco, '24 Grenadier -ordered
Very cool but it all comes down to pricing. So much lighting is priced at a point that I just canā€˜t stomach. It isn’t that I can afford it but rather I don’t see the value for the dollar.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Let me see if I can talk about pricing yet. It's nicely priced i'll leave it there for now :)
KillerPenz
North East
Sweet... 400 bucks! We'll all take a set.
To be honest, I got the XRGB's @ $1125 on sale. Which at the time were the lowest priced (Non-Chinese, which is debatable) at that time. Everyone else seemed to be in that $1600 range. So not quite sure what you consider to be nicely priced. Especially since I've been having issues with the XRGB's (going on my 3rd replacement now).
