New 2025 base
KevinInChicago
Kevin
CHICAGO
Roush F150 and many others
Put on the "Braptor" boards from some Bronco Buttercup website today. Not bad $500, don't need the rock rails for them to install. Took about 30 minutes with 20 fasteners total for a 2 door. They have a decent Rhino Liner type finish, maybe a bit tougher but not scratchy. Went on pretty easily. Ford wanted similar ones I was looking at off the Stroppe but those would have been $1300 or more to do that. These are fine for my Base. Keeps the rocks off the doors from the tires and wife can get in easier. Very sturdy since I am 275lbs and they don't flex at all with me jumping on them. Hardware seems to be all stainless. Now I am done.... I do have the Auto Stop Eliminator arriving Monday so then, for sure, I think, maybe yes, I am done.... I will unscrew and take off the "Braptor" logo that is on these boards. I don't like words on my clean Bronco. Just me. The boards cover up the seam underneath and the wires that showed on the frame that were annoying me also.
Ford Bronco New 2025 base board left
Ford Bronco New 2025 base board right
Ford Bronco New 2025 base board to
bf4445
Britt
Oregon
2007LarietCC4x4, 2018FocusTit, 2016Jeep reneTH
Very nice.
UncleBrad
Brad
Indiana
2024 Bronco 2-DR Manual
Update: did the ProCal4 performance tune on the 2024 Big Bend two-door 2.3L 7MT. Super impressed. The rear seats are removed, and the vehicle is about as light as a Bronco gets (with roughly stock tire size). Just over 6 seconds to 60mph. There is a noticeable improvement in throttle performance and turbo boost, though there is still too much turbo lag. Torque availability at lower RPM is much better. The Ford documentation for the ProCal4 package is poorly-documented. There were several "something probably happened/I guess it's done" scenarios, but I had no trouble and no drama installing it.
I got mine at levittownfordparts.com.
bf4445
Britt
Oregon
Is this a Ford part?
UncleBrad
Brad
Indiana
Yes. It is a Ford Performance product, with a warranty, etc.
There are different devices & tunes for the three different Bronco engines. Mine is the 2.3L:
Ford Performance Calibration With ProCal 4 Tool For 2.3L Engine Part Number: M-9603-B23 $660.05
There is lots of info on the ProCal4 on this forum, YouTube, etc.
bf4445
Britt
Oregon
thanks
KevinInChicago
Kevin
CHICAGO
The manual Bronco has drive modes. I know in an automatic it changes throttle response and transmission shift patters. What does it do for a manual one? I know in sport mode, auto start stop is turned off and I get orange gages with now a boost gage and battery gage different than normal. It seems to act the same for me in the manual.
bf4445
Britt
Oregon
good question
UncleBrad
Brad
Indiana
I had the same question - what does the GOAT modes do for me when I have a manual transmission and no 4A, torque-vectoring, locking diffs, etc? I really never got a direct answer, but - I think it does very little. I notice only quicker throttle response. Probably turns on/off traction control in some modes. Maybe a change in timing (don't know). I haven't tested with the newly-installed ProCal4 in Sport mode, but I suspect that GOAT is just a gizmo/gimmick for the most part when you have a manual transmission.
The forums and Ford itself never really seems to the question you asked (because 4-door automatics are the bulk of discourse). Hopefully someone will jump in?
KevinInChicago
Kevin
CHICAGO
I now have absolute respect for those who can get a base model and keep it a base, wheels and all. I found I was not strong enough to avoid temptation and change things on mine. It did turn out like I wanted, but there is absolute charm in keeping a base as simple as possible to honor it's past from the first generation it was modeled after. There is another in my neighborhood in ingot silver, 2 door, base with a manual from 2021 the first year. He has actually worn down his original pizza cutter tires, imagine that. The pizza cutters match nice with the silver Bronco. I bet there are just a handful who ever accomplish that, the pizza cutter gang, my membership was revoked.
Ford Bronco New 2025 base Bronco 2025
mb86gt
Matt
KC
06 Silverado
Great looking base! I ditched the base wheels for bd black steelies.
Ford Bronco New 2025 base IMG_5526
MNBigfoot
MN
It may tighten or loosen steering, disable traction control, or enable lockers, see below:
Ford Bronco New 2025 base goat
UncleBrad
Brad
Indiana
Thanks for posting this!! So there we have it: where we see the asterisk under the "Trans." and "Drive" columns are what we are missing in the GOAT modes as 7MT owners with in base trim. What we get is changes to traction control, throttle, steering, grille air dam and exhaust. Of course we're also missing two GOAT modes altogether.
bf4445
Britt
Oregon
Well i have wondered the same thing as with my Jeeps which have something similar I don't really notice any change. Mine have all been automatic trannies
