Need help with plugnplay harness pins!
schlava
Delaware
2022 F250; 2021 Bronco OBX
Hello. I'm stalling my kicker key amp using the plug in play harness. Everything worked fine until I ran the wires behind the dash. I went to turn everything on and no sound. It turns out a wire pulled out of a pin in the harness. How do I remove these pins to reconnect to the wire?
Thanks so much it's sounded so good while it worked!!!
KABQ
Aaron
Albuquerque, NM
