Muffler delete, adding resonator, but where and why
ClappinCheex369
Joseph
Clarksville, TN
2023 Ford Bronco
So the wifey is going to do this for me for my birthday next month.
I’m planning to do a muffler delete and adding a vibrant bottle resonator.
I feel like I’ve seen them being added somewhere midway and also basically where the muffler was but going straight out.
Does anyone know what the pros and cons would be for each location?
RedBeardoh
Matt
WA
2019 Ford Ranger
Curious to see a sound clip when you get the install done (with resonator). I have a MY 25 with the new 2.3, did a MF muffler delete and love the sound! I don’t care for the cold starts, it sounds like a hippo farting through a megaphone 😑 but once it calms down it sounds great and isn’t as loud as I’d expected with normal driving.
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
Midway, so you can add the larger DV8 under cargo box.
RedBeardoh
Matt
WA
2019 Ford Ranger
Good point, didn’t even think about that. I added the DV8 compressor box and love it. Would have been a shame to get denied by a resonator
EvilJim1971
Jemison Al, 35085, USA
www.instagram.com
2023 Bronco Heritage Edition
I would go midway under the vehicle.
I have the AFE Apollo GT High Tuck and that's where the muffler is on it.
And lots of room in the rear if you ever wanted to add anything back there.
Roland
Ohio
2022 Bronco
I tried this route with two different resonators, both in the mid position. One was an Amazon special the other a flowmaster. I really liked the sound but the drone at 1600 rpm is what made me switch to a cat back.
Also don’t run the exhaust without the muffler too much as you will end up with melted plastic on the bumper.
RedBeardoh
Matt
WA
2019 Ford Ranger
Are you referring to simply running with no muffler? I went with a muffler delete pipe, can’t remember if it was rough country or flow master but it’s just a pipe that directs the exhaust at the ground. Been on for almost 6 months now zero melting issues
