Mud Flaps/Splash Guards with rock rails?
rodeobri
Hyundai Santa Fe, Ford F250
Hi all,
It's now effectively winter here in Colorado and I don't have mud flaps on my 2022, 2 door Badlands. I do have rock rails, however, and the basic $53 front mud flaps from the Bronco Accessories site won't work. However, they offer an option for $499!!! (just for the front).
Are there any after market options that are recommended?
Thanks in advance!
DEC
Derek
SoCal
BMW 640, Mustang Bullitt, Mazda 3, Honda Accord,
They do work with some modifications. Just trace out the shape and cut with a Dremel.
Ford Bronco Mud Flaps/Splash Guards with rock rails? 6FAE2D09-FCC4-4F12-8ECD-750511E0A8A2
Bt_ostate
Oklahoma/Colorado
2021 Ranger Tremor 2021 Bronco 4-Door FE
Hi all,
Thanks in advance!
Gatorbacks have some designed especially for rock rails and they work great!
rodeobri
rodeobri
Good to know, thanks!
FotoBroncoDan
Dan
colorado
2004 Subaru Impreza WRX STI
I used the rally armor universal SUV sized flaps, they fit fine. Just need to drill the holes to line up with the existing ones on the bronco. I have had mine mounted via 3 bolts for about 6+ months now. You may need a spacer. I only did my front wheels, rears dont really have a good way to mount. So far it Works great, ZERO rock chips!
kimmnen
Kim
Transit Connect & '22 Bronco Badlands
I have a Badlands with the factory rails. Just did a DIY using $28 Black Polymer Mudflaps 24x24" from Amazon (listed as 24x30 but spec is 24x24). Used one panel and split in two. Since I didn't screw up, I have a panel to use if I do rears. Made brackets from aluminum stock I had and a small purchase of 2" 90-degree aluminum angle stock. Stainless nuts/bolts flap to bracket. Used nylon wingnut/bolts to make quick removal of flap (or to access flare lever if needed) along with removing 2 nuts securing bracket to bottom of crash bar. Was able to get flap between rock rail and inner fender/crash bar. As installed, the bottom of the flap is about 7" from the ground. Now I need to find some mud/winter to test out.
Ford Bronco Mud Flaps/Splash Guards with rock rails? 1mf
Ford Bronco Mud Flaps/Splash Guards with rock rails? 2mf
Ford Bronco Mud Flaps/Splash Guards with rock rails? 3mf
Ford Bronco Mud Flaps/Splash Guards with rock rails? 4mf
Ford Bronco Mud Flaps/Splash Guards with rock rails? 5mf
Ford Bronco Mud Flaps/Splash Guards with rock rails? 6mf
Ford Bronco Mud Flaps/Splash Guards with rock rails? 7mf
Ford Bronco Mud Flaps/Splash Guards with rock rails? 9mf
Ford Bronco Mud Flaps/Splash Guards with rock rails? 10mf
Ford Bronco Mud Flaps/Splash Guards with rock rails? 8mf
Ford Bronco Mud Flaps/Splash Guards with rock rails? 11mf
helifino16
Ron
Mount Sinai, NY (Long Island)
Contact @Biltwild - he’s got a solution that is elegant and simple. I know he’s been working on it a while, so he should be ready to share it.
