Mud flaps for Bronco raptor
Waldramos
Walde
Puerto rico
Bronco Raptor, Raptor 37
Hi guys
The only alternative of mud flaps for the Bronco Raptor Are the rokblokz?
Thanks
topdawg4ever
Ohio
Mustang Dark Horse, Ram 2500 Cummins, AT4 Yukon-(Bronco Raptor-Future)
Can’t really answer your question,but can tell you I’ve had rokblokz mud guards before and they are an excellent product. Haven’t made a commitment yet, if I’m pulling the trigger for these on the Raptor.
TheLawnDart
Austin
Las Cruces
FJ Cruiser, Subaru Forrester, Hyundai Palisade
I’m a big fan of the RokBlokz. The price is steep, but it’s saved my doors.
Ford Bronco Mud flaps for Bronco raptor CBA9E6F5-1029-4E59-92C0-6FDB59EA2B97
Taltyman
Paul
Forney tx
Jeep wrangler Rubicon, Ford F350, Braptor
Hi guys
Thanks
Just bumping this as I have the same question.
defector69
2023 Braptor
Literally another thread in this folder on this topic. Weathertech. 40% the price.
RowsKing
JR
SJ
22 BRaptor, 66 Stang
Mud flaps for the Raptor?
Ford Bronco Mud flaps for Bronco raptor 1700264515128
Taltyman
Paul
Forney tx
Ordered the Weathertech, will see how they work out.
swamp2
Taltyman
Paul
Forney tx
Installed the weathertech mudflaps. First thing my wife said was the rear flaps didn't follow the flow of the original mud flaps. So they look like kind of goofy. But they do extend further and as we drive a lot of grave roads then hopefully they will prevent rock chips. The front ones went on pretty easy. The back ones not so much. They claim no drill but you have to use self tapping screws (4 on each side) with very little clearance because of the rear tires. You've basically got a couple of inches to try to get a screw started in plastic. Really struggled with being able to get enough pressure to get them started. Then I decided to take a lighter, hold the screw with pliers and use the lighter to get the end of the screw real hot and then push it into the plastic. That allowed the screw to penetrate and was able to get them threaded in much easier. They tighten down with a threaded metal piece on the other side of the plastic.
Bschurr
NY
Can you post some pics ? I am considering the WT mud flaps too.
Thanks in advance!
Taltyman
Paul
Forney tx
Here you go. The last picture shows the area you have to get the screws installed on for the rear mud flaps.
Ford Bronco Mud flaps for Bronco raptor 3
Ford Bronco Mud flaps for Bronco raptor 4
Ford Bronco Mud flaps for Bronco raptor untitled
Ford Bronco Mud flaps for Bronco raptor 2
