Minimum lift required to run 37 inch tires on Everglades Sasquatch ?
Noel
2023 bronco Everglades
Everglades
Looking for the minimum lift required to run 37 inch tires. No plans to do major off road, just drive the beach in Florida. I realize the question has been asked before but I am not that bright. Thanks in advance.
c00kedg00se
Andrew
Boise, ID
LR2, Expedition, Bronco
interested in the answer
rguest3
Raymond
Florida and Virginia
F-350, F-450, 23 Bronco, 24 Raptor, (2) 77 Broncos
Do you want to keep and install the Factory Wheels? Wheel offset makes a big difference.
With the Everglades Fender Flares you may be able to install 37s with no lift at all.
Rear is fine with no lift. Maybe just a 1" level lift up front.
Mdsuits
05 f350, 68 bronco 89 samurai
I put 37 on my Sasquatch badlands and wheeled it pretty good that way. (I have negative offset wheels) it would rub on the flares flexed out. I wouldn’t recommend jumping it with 37s with no lift since I could get the Goodyears to lightly rub the fenders that way. I ended up lifting it a 1-3/8” when I went to icon shocks.
atlawson
Tracy
Rose Hill, VA
Bronco 2022 Wildtrack Lux w/ Sasquatch
What offset do you have?
Bradley Thornton
Bradley
Hattiesburg MS
