Mini-Mirror in side mirror
PSUTE
Western Maryland
Sierra
Cool. Did not know my Basesquatch would be equipped with it. Guess some folks need an electronic babysitter...
4avor8ntfair
Houston, TX
BL-non SAS, 2.3 auto
I liked the convex mirrors in my explorer, but it didn’t have BLIS. I was pleasantly surprised to see that my BL High came with BLIS, probably mainly bc I never paid attention to the details of the Copilot360 pkg.
4avor8ntfair
Houston, TX
Everyone eventually gets fatigued driving or has a bad day and could use the assist!
HoosierDaddy
__ Eric
I LOVE the dual mirror set up the Super Duties have (at least the older ones like the one used to have) You couldn't hide in those mirrors.
On the Bronco, I wish the convex part was at the bottom, not the top corner. Maybe just because that is what I got used to on the f250, though it's been over a decade.
Like these:
Ford Bronco Mini-Mirror in side mirror 1641113015108
JerryC
Memphis
2022 Bronco
I've noticed that when I drive car with BLIS, people don't sit in my blind spots. I figure that's because they can see the lights in my mirror.
Efthreeoh
Hummer H3T
From an article I read in car and driver decades ago:
To properly adjust mirrors, sit in the driver's seat and lean your head left until it touches the driver's door window. Adjust the driver's mirror so you can just see edge or the door handle.
Lean right the same distance from the seated position and adjust the right-hand mirror in the same fashion.
Efthreeoh
Hummer H3T
Man, I'm glad I accidentally got BLIS on mine then (which is permanently disabled). I was pleasantly surprised to find that my mirrors didn't have those annoying things in them. The only reason a car has a blind spot is if one does not have their mirrors adjusted properly.
Agreed. I'm hoping the BLIS mirror glass snaps into the base mirror housings. Not a fan of built-in blind spot mirrors. Once part issues settle down, I plan to make such a mod. I need neither assistance.
FlyersFan76
SEPA
Land Rover Defender, Land Rover Range Rover Sport
Like these:
Agreed. The present location just gets in the way of what you actually want/need to see.
FlyersFan76
SEPA
Is there a part# on them yet? Even with the arms as a full replacement?
Efthreeoh
Hummer H3T
I've not yet checked. I think it is too early to consider swapping ancillary parts like mirrors considering limited parts availability.
Daktari
Oliver
while I have my mirrors adjusted "correctly" to eliminate blind spot, I've had little blind spot mirrors on my Tacoma for 18 years and got so used to them, I put them on my BL again. I do have BSM too, but for the first time, felt better with the mirrors where I can see everything, from wheels to the moon :cool:
Oh, and don't replace your mirrors, there are tons of options on Amazon and elsewhere, probably even at your local gas station. Just get some you like and stick them on :)
FlyersFan76
SEPA
I think for my case and others it is not the fact that there are blind spot mirrors it is the fact that the mirrors are located on the top outside portions of the mirror. That is the area that I and others need to see normal not a smaller version of what is around you.
