Mikellis Body Lifts
Mudlight
Brent
Badsquatch
mikellisbodylifts.com has lower height Body Lifts like:
* 1/2"
* 3/4"
* 1"
* Coming Soon 1.5"
* Coming Soon 2"
Or you can purchase custom size pucks also. I have installed 3/4" Body Lift on my Bronco, Mike is easy to work with, super fast shipping, and a fraction of the cost. Check it out, just thought I would share.
Ford Bronco Mikellis Body Lifts 1679578248626
Ford Bronco Mikellis Body Lifts 1679578300050
Ford Bronco Mikellis Body Lifts 1679578363228
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Did you get new hardware? I saw a post where a guy figured out he could reuse all stock bolts if he went with a 5/8" puck.
Mudlight
Mudlight
Brent
Badsquatch
Only for the front b/c I have the JKS kit. You can use a 3/4" body lift with the stock bolts accept for the front 2 bolts with the JKS Max Tire clearance kit.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
What‘s the difficulty level installing these? Never tackled a body lift before. Think 1/2” or 3/4” to help with the 39’s
Like 20 minutes with an impact and stupid easy. It's a solid 6 beer job if you do it one handed.
JustJoshnRound
Josh
Rutledge, TN
www.youtube.com
2026 Ford Explorer ST / 2025 Ford Bronco Raptor
Our snorkels make the body lift impossible for us….it’ll snatch at the intake since it’s body mounted and the engine isn’t.
AGM Everglades
Everglades
Los Angeles
5 early broncos, AGM Everglades
Everglades
Didn’t think about that. Makes sense.
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
Shouldn't be a problem based on pictures I have seen of everglades snorkle. Air cleaner box is mounted to the body and the hose from the airbox to the engine has TONS of flex. Snorkle to airbox connection would stay exactly the same
JustJoshnRound
Josh
Rutledge, TN
www.youtube.com
Shoot you’re right! I had to double check cause I thought the air box wasn’t body mounted.
Great…yet ANOTHER part I need.
Mudlight
Mudlight
Brent
Badsquatch
Body lift is super easy like stated above, 30 minutes tops. I think the smaller body lifts look great! I ended up with a 1" I started with a 3/4".
Ford Bronco Mikellis Body Lifts 1681736369570
GToddC5
Todd
South Jersey
www.bronco6g.com
^ Looks awesome! So did you start as a BaseSquatch and now it's +1 body lift? What size are those tires? Thanks!
Edit: NVM, I found some of your past posts with lift info.
Mudlight
Mudlight
Brent
Badsquatch
Thanks! Yes, Base Sasquatch. Yes 1" body lift. 38.5x13.50x17 Super Swamper Boggers.
AGM Everglades
Everglades
Los Angeles
Everglades
Yours looks great! Suspension goes in this week so we’ll see what it takes to squeeze these tires on.
Waiting to order my BL until I get a better feel for what size I’ll need. Prefer to do it once.
Mudlight
Mudlight
Brent
Badsquatch
Thanks! Can't wait to see it!
