Rayder
Brighton,MI
F-150
I would venture to say this is the material that a lot of the members on this board are claiming is cardboard. It took 2 minutes to search and find this, and I really don't believe an advanced car company beholden to its investors, would produce $40-60k vehicles with cardboard reinforcing the top...just sayin
I wish, she's cardboard unfortunately, this is from Webasto's sell sheet on the product.
Ford Bronco MIC Top 1.0 inside construction & material (cross section) - pics Screenshot_20211104-131117_Chrom
Rkgzx9leftcoast
Robert
Scottsdale AZ
Jeep JL
A multi Billion Dollar company.....all they had to do was buy a jeep hardtop and reverse engineer it.... what has been working for decades. They didn't ask the right people.... and way to many so called experts still have their jobs......
RoLyMa27
Rodney
SloKart, TX
21 Bronco 2dr, 26 Explorer ST
You are correct that car inflation has been quite low for the past 20 years
In January of 97 I paid $21,900 for a 97 model F150 XLT. (sticker was $24,555). It was an extended cab with the third door, 5.4 V8. Nice truck!
THE 2019 F150 XLT FX4 crew I bought in January of 20 stickered for $55K, I paid $45k! Y'all consider that low inflation???
rugbysecondrow
Pauly P
north carolina
1964 C-10 stepside
I'm no top expert, but the innards don't appear to be the problem, right? The issue seems to be the outer layer of construction.
All this hand wringing about what the inside looks like is fraught with concern but would be much ado about nothing had the outer layer been constructed better and more consistently.
Seems like misplaced angst, IMO.
heavyD
Calgary, Alberta
2025 Badlands 2-Door
Everything is built to a cost. It's not likely that Webasto can't build decent roof panels. It's likely that they are having trouble building these panels with profit margin which is why corners are being cut. Auto manufacturers grind their suppliers to supply quality products for as cheap as possible and sometimes the suppliers bite off more than they can chew. It certainly appears to be the case here. I would have no issues paying $500 more for a Bronco if it was going to come with a higher quality roof and maybe Ford should consider raising the price on the MIC tops if suppliers can't build a quality roof at the current price point.
SasBLSven
Steen
Kearney, NE
2017 Audi Q7
Hello! My store recently replaced a MIC 1.0 top for one of our customers, and part of the replacement process required us to cut up the old top panels. Would anyone be interested in seeing the inside of the MIC top?
Edit: Below are some pictures that I took of the MIC 1.0. After inspecting the top and seeing just how thin that outer shell is, I can see why the honeycomb structure of the top was showing through when exposed to extreme heat/moisture.
2021 Ford Bronco MIC Hard Top 1.0 construction material cross section inside 3.jpeg
2021 Ford Bronco MIC Hard Top 1.0 construction material cross section inside 4.jpeg
2021 Ford Bronco MIC Hard Top 1.0 construction material cross section inside 5.jpeg
2021 Ford Bronco MIC Hard Top 1.0 construction material cross section inside 2.jpeg
2021 Ford Bronco MIC Hard Top 1.0 construction material cross section inside 1.jpeg
And that's why the to is under $700
PDiddy
Paul
4Runner
Now, I am no expert at interneting, but I can not find a single section image of a Wrangler hardtop. Apparently, people have not needed to cut one up.
I have a soft top now. I think I will skip past a Ford hard top and buy an aftermarket one, when available. I love my Bronco, but quality control has not been priority 1, 2, or 3.
mdonathan56
2022 Bronco Bad,2016 Q5 TDI, 2009 Honda Element EX
This is a paper core coated with a resin to make your desired density core, i.e. 2, 4, 6 or 8 pounds per square foot. Worked the Aircraft industry and saw enough core to last two lifetimes.
mdonathan56
I think the confusing part for me is why not just make a single-layer fiberglass top? Maybe reinforce the edges where the roof rack connects and put some decent insulation inside. Why does it need to be a composite sandwich?
Full disclosure, I know nothing about tops so there may be an easy answer to this.
one word; Weight.
Fonz54
Lou
Monterey, CA
Jeep Commander, Porsche Cayenne, Mercedes C250
If this bothers you then you never want to visit an assembly plant to watch how your vehicle goes together.
You might like to eat the hot dogs but you probably don't want to see them being made.
FLSTFI Dave
East TN
2018 Grand Sport, Carbon 65, 2017 F-150
Yep, they make the top for the Hard Top Convertible mid engine corvette. They make this top to GM's specifications and what they said they would pay for it.
They are making this MIC top to Ford specifications, and what Ford said they would pay for the top.
To me the issue is not what's in the middle, its the inner and outer layers are too thin, and the edge seams are not well sealed.
