Mesh or solid bimini top?
PearlJamFanLV
Las Vegas, NV
2023 Big Bend, 2 door, 7spd
I live in Las Vegas and was wondering what type of top to get. I have a 2 door hard top. Driving around with doors on and top panels removed is so much fun, but I certainly need something to stop the direct sunlight. What are most of you using? I want a mesh but don't want it too bright. But then again a solid top there is no ambient light.
Has anyone tried both?
da_jokker
Jeep Wrangler JKUR
I have anything for the Bronco yet, but for my Wrangler I went mesh. It blocks a ton of light, yet still gives you that feeling of open air because you get sunlight and wind through it.
Now admittedly, with the Bronco it's a much larger area (at least in the four-door) But to me putting a solid top on kind of defeats the purpose unless you are trying to keep rain out.
And again I don't know about the Broncos specific, but with my Wrangler my mesh stays on even when I put the freedom panels back in. So the mesh allows me to actually see through them and I can use that area for storage (light items of course)
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
I went mesh over solid canvas. I still wanted it to seem open air. Plus the mesh allows air to pass through more, for more breeze and less flapping.
djp
djp
Idaho
'22 Badlands 4dr || '21 Bronco Sport BigBend
Area51BS
Ron
Badlands non SAS 4dr 2.3
I have neither. But getting mesh for reasons stated. I also want a solid insulated style from dirty dog. For a few reasons. Less noise on long trips as it supposedly cuts down in noise. And want to see if it helps with 97 degree heat this summer in FL. Not so much that it has a high R value but it might block a little bit more heat when idle and no cooling effect of air flow over the OEM top when driving.
adamruiz2001
SoCal
Ford SVT Lightning
LOL bro, for a second, I read it as you installed a mesh top over a solid top, I was straching my head like, why the hell would one do such a thing, man, I have been at work to long today and need to go home 🍻
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Mesh
- no Bimini is protecting you from rain.
- mesh gives you sun protection and airflow for ventilation in the heat
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Haha. Totally can see why you would think that. Guess it could be interpreted differently, lol. You know what I meant now.
zedster
Las Vegas
'21 Bronco 2 dr Badlands SAS, '22 F150 PowerBoost
TriggerTX
Trigger
Austin
61 Ford T-Bird, Autozam AZ-1, Golf R, Suburban 4x4
Had both for my D90. Used the solid almost all the time. I never used the full top, like ever. I got caught in enough popup thunderstorms in Texas to learn. I'll still get wet but with a solid top at least I'm not completely soaked through nor is all the stuff I'm carrying. Haven't made the decision on the Bronco. Likely go mesh as if rain looks imminent I can pop the front panels on pretty quick.
AZMikeL
AZ
2022 Bronco Badlands 4dr, 2016 BMW 435i
Mesh - I have the gear shade installed and leave it in all the time. Also a hat of some sort as I'm folicly challenged on top!
