Manual sway bar disconnect
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I believe that’s just a single replacement part to the kit. You can’t just use those with the factory links.
Factory on left, AC Fab on right. Old pic, but you get the idea. AC Fab has improved theirs since and I believe there is at least one other manufacturer making them at this point.
Ford Bronco Manual sway bar disconnect IMG_5875
Fordified1
Bob
Mid South Texas
Are these noisy when connected?
redone17
Cold Spring, NY
Copperhorse73
Justin
Mooresville, NC
Why not use rubber/urethane bushings for the links, then there is less worry about maintenance and clunking? A lot of my vehicles had rubber sway bar link bushings.
I’ve wondered the same. The metal ones do like to start clunking. I want something like the Rock Krawler ones I had on my Wrangler
Hashlak
UAE
Bronco Sasquatch, Porsche GT3RS, Honda CBR1000RR
I just installed these AC fab disconnecting links like two weeks ago and they are clunking quite a bit.. have not even been off-road and it's really not so nice.. lubing doesn't help because it's the lower link where the lynch pin is.. even with the rubber o ring.. still annoying and I personally don't recommend.
SuperDave150
Lubbock, TX
Ford F-150, Ford Edge
@Hashlak thank you for the honest review.
SuperDave150
Lubbock, TX
I tried the links and ended up ditching them for a RocJock. I am pleased with my RockJock; it works better than a disconnected sway-bar in my opinion.
Ok I get it. A soft sway bar (always connected) instead of a stiff sway bar (that you disconnect and reconnect).
One more upgrade
Joe Mogush
22 Tesla Plaid X 22 Escalade
Curry has some good YouTube videos explaining how it works. I love mine; I am waiting for them to release their rear RocJock. It has drastically improved my articulation.
SuperDave150
Lubbock, TX
Oh yes @One more upgrade I’m sure it does exactly as you say it does.
redone17
Cold Spring, NY
I’m swaying in that direction too. Pun intended. The Boss Links look promising for half the cost. But, an upgrade is imminent. Oscar just sent me my 2nd replacement lower brackets. First pair was before they were welded. Second pair driver side weld snapped the other day on a pretty light trail in a rock garden (I didn’t have them disconnected).
Ford Bronco Manual sway bar disconnect IMG_5872
orion
Jeremy
17' F-250, 17' Explorer
Or just pull your swaybar off and be done with it! That is what I've done and it is not sway'ee at all to me. LOL. I pulled the swsybars of my Land Rover Discovery and that thing swayed a lot. The Bronco, still corners real good without.
Fordified1
Bob
Mid South Texas
Pulled mine off also. I can tell a difference but it’s not horrible. Tried that on the Gladiator and it was almost dangerous without it. Been running the Excursion without a front sway bar for a decade.
