Maintenance 4x4 alert
Dondemp21
Don
Hanover, PA
2025 Bronco
I recently changed the tires from the stock 255/70r16 to 265/70r17 on my Base. Yesterday I logged into forscan to change the tire circumference. When I took it out for a drive fir the first time, the 4x4 service light powertrain malfunction / loss of power.came on with a service soon light. I just had the oil changed at about 6k miles. 2H seems to run normal. I did take it by the dealership before they closed yesterday and have an appointment Aug 19th. I don't know if these connected, have seen many post about this issue. I drive about an hour to from work, my concern is doing damage till i can get in.
Need to do the PCM initialization as part of the tire size calibration - it’s in Forscan as well. Don’t think you will break anything in the mean time but the light won’t clear until you do, and GOAT stuff probably won’t work
Dondemp21
Don
Hanover, PA
2025 Bronco
Need to do the PCM reset as part of the tire size calibration - it’s in Forscan as well
I am new to Forscan, sounds good, I'll go out try that. Thank you
