Lower control arm mounting point damage. Should I be worried?
GrumpyVet
Joel
BAUS67
redneck
Central PA
rtazz17
Rob
Connecticut
2022 Ford bronco big bend
Biggest worry I would have at this point is the alignment. It almost certainly moved. Camber is prolly off now. Not really something you will feel in steering if its only slight but if its your daily driver you will see it in inside or outside tire wear.Definitely would be looking for a protection plate for that.
IwannaGOfast
Jon
Brea, CA
2021 4 door Badlands, 1991 Ranger Long Travel, 2014 Cruze Commuter
Mine looks like that. I was thinking about getting the Barnes reinforcement kit, it's dirt cheap.
Those are dirt cheap, didn't know they existed. Seems like some of those slots would get in the way of the alignment cams. I guess you could just grind down the slot welds that interfere. Would probably look cleaner to just grind them all.
OffroadBandit
OffroadBandit
Georgia
Ford F-150
I didn't find one for the front lower control arm mounting point. You happen to have a link?
Also, did you get an alignment done following the damage? If so, was there a change?
mpeugeot
Hi there, I'd be happy to look into your Bronco concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
Tell them the truth... It's ruined! They have only on reasonable course of action at this point. Sell it to me as salvage for $0.10 on the dollar.
IwannaGOfast
Jon
Brea, CA
Frebaln
Shad
So Cal
72 VW Variant (Squareback)
OffroadBandit
OffroadBandit
Georgia
Ford F-150
Another update, got the thing jacked up, here's the inside. How borked am I? That washer(?) on the inside is bent as well.
Ford Bronco Lower control arm mounting point damage. Should I be worried? PXL_20230127_012317001
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I haven't yet because I'm about to put new coilovers in and wanted to wait for that. My steering wheel is a bit off center but it drives fine.
Chrome_Pony
Chrome
The Great Land
Get at it with a hammer and punch enough to get that washer away from rubbing on the LCA bushing and let it ride. Alignment is probably tweaked slightly.
I would order the gussets and the LOD skids if you're worried about it happening again, line up a shop to weld them and straighten the bracket, and then get an alignment after, then bolt on the skids.
