Looking for 2.3 owners input
Thanks for posting this. I assume the Ford performance gauge "octane adjust" on the ProCal is the OAR reading discussed (can anyone confirm or deny?). He describes a driving procedure to try to get it to activate and adjust to your good fuel:
I just checked mine - it’s called Lrnd_Knk_Mod
Ford Bronco Looking for 2.3 owners input IMG_2336
The note for OCt adjust says it’s either off (0) or on (1) - so not sure what that is
I’ll say since I’m showing what mine is - I get 91 octane every time, mostly from one of 3 Top Tier stations near where I live. I do a lot of hilly driving and have a lot of extended pulls on grade at boost
From the article linked by @burgerking
If the engine knocks badly at any time, it will move the other way, towards its low octane tables, thus lowering load and ignition advance allowance. It’s position between these blending tables is indicated by the OAR Figure which will be somewhere between a best of -1.00 (High-97) and a worst of +1.00 (Low-93) A middle position is an OAR of 0.00 (95)
So I’m sitting at -0.63 — probably makes sense for 91 octane on ProCal. It as adjusted upwards some but didn’t hit the limit of max performance. I’d expect that number to slide closer to -1 if I ran 93, and slide positive if I ran non-premium fuel.
crenca
Southern New Mexico
Thanks for posting this info - I just added Lrnd_Knk_Mod and mine is reading -1.0. My E85 mixing strategy must be enough. I make conservative assumptions, for example that the E85 I'm using is 99 octane (possible, particularly in winter, though it is probably higher). Perhaps my average tanks are closer to 93.5 or 94 thus I'm maxed at -1.0
@burgerking , are you mixing your E85 with premium (91 or 93) or regular 87?
So - thinking about this. I think I had the system pretty close in description. I didn’t know about the setting memory though - and now it’s been fairly confirmed it does.
So - does that change my recommendation on running lower-than-recommended octane fuel (with or without a tune, really does not matter)?
No.
I still would not recommend it. The knock reduction system will protect your engine (to an extent), and the OAR system will “remember” your octane rating between startups. So that does help. A lot actually. But it still won’t account for random changes in octane between fill ups, or if you decide to actually follow the recommendations one day and then go back to junky fuel the next fill up.
I’ve never intended to suggest that not following the fuel will grenade your engine instantly - it won’t, and I believe I’ve been pretty clear in admitting that. But I think a lot of people are conflating “won’t grenade” with “perfectly safe” — the damage comes from additional knock over time with the engine constantly (or maybe not constant, but certainly more frequently than otherwise) playing to downtune. OAR does mitigate that a lot, but doesn’t eliminate it, or negate the fuel octane requirements
That said - I only control my car. My advice is worth what you paid for it, and you do whatever you believe with your vehicle.
Ducati1098
Y’all mix your E85?! That must suck 😝
userdude
Denton, TX
2023 2dr Badsquatch
I wasn't able to find the same screen (at least it didn't match yours), but here's my readings:
ACT2
122
KnkAdder
0.0
KnkSen1_Cnts
999
Lrnd_Knk_Mod
-0.95
Oct_Adjust
I use 93 exclusively since probably 3k miles, and get Buc-ee's primarily, but Exxon/Shell/Chevon/Mobile/Phillips 66 if I have to. I have a fillup right now of Buc-ee's but over the weekend had two straight fill ups elsewhere (Mobile and Phillips 66).
It seems like the Lrnd_Knk_Mod is good? Why would KnkSen1_Cnts be 999?
Oh I was just using the data logging screen - you can set whatever parameters you want there. You found the setting, I believe it’s in Spark or Ignition - can’t remember the exact name.
I dunno what the Counts fields are - some of it may be extraneous junk meant for use with other engines.
userdude
Denton, TX
2023 2dr Badsquatch
Hopefully my characterization has been accurate; that's what I thought you were saying, at least, which makes sense to me. No grenading, just that unnecessary knocking can accumulate.
crenca
Southern New Mexico
Straight E85? Now that's not in the manual that I can find :p :wink:
Perhaps the injectors can handle it, at least with a specific E85 tune? Frankly I would rather run straight E85 if possible but I have not even bothered with a basic Google search for such a tune...
userdude
Denton, TX
2023 2dr Badsquatch
Ok. I hope that doesn't mean it's counted upwards of a thousand knocks. I do notice some days it does feel like the engine is sucking wind.
I found the data under a couple menus, one was Datalogging > Gauges > Spark > Lrnd_Knk_Mod (which is what I thought you were talking about), and another one, I think ACT2? Not a very graceful device to work with.
userdude
Denton, TX
2023 2dr Badsquatch
Ducati's got that stage 3 (?) turbo w/ZFGRacing tune, I don't know if that matters. Y'know, full on truck nutz territory. lol :whistle:
Ducati1098
Lol nah I’m just in the wrong section. I forgot the thread was originally about the 2.3.
If you have a 2.3, unfortunately straight E85 isn’t an option both because of the lack of custom tune and the stock fuel system couldn’t handle it.
I just figured I’d get a shot in as someone that has a 2.7 😉 I’ll see myself out now haha
crenca
Southern New Mexico
Well, the FP tune on the 2.3 does make a real difference in the 2-4k rpm range, but from 4-6k it runs out of breath, the additional 30HP not really adding that much over stock. However that mid range torque is worth it, particularly in-gear acceleration with a manual and its wide(r) spaced gears. A different turbo with more high end would be a upgrade, but so would the 3.0L Raptor engine :)
We have 87, 89 and 93. The way the prices break down at the station I usually go to it's cheaper to use half 87 and half 93 than it is to use 89. So I started doing three transactions. It's a little inconvenient but I don't care.
That’s kinda funny because at most stations, they only have tanks for 87 and 93, and the 89 is just a ratio of the two mixed from the pump anyway.
Prurience
K
Lexington
Jeep
2.3 Auto 2-door. I don't even usually run it in sport mode and I love this engine. Feels very quick. If I drive it like my wife I get 23mpg even 24 when it's flat terrain.
