Lightest 17" wheels *with positive offset*?
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
Anyone got any tips on light 17" wheels that have (any amount of) positive offset?
Best I can find so far are method 705 at 25.3lbs/ea
I'd buy the very expensive Titan 7 wheels today if they were positive (rather than negative) offset
All Rays/gramlight/Volk and Motegi that I've seen are all zero or negative
I don't need poke I need trail clearance and rock flinging mitigation
Appreciate any help!!!
F OR D
BD Green Machine
curious why so weight focused? i get rotational weight but for a close to 4k+ lb vehicle i do not see counting grams or ounces, let alone a few pounds.
i mean the rtr tech6 or evo6 are +30 and weigh around 25.5lb. i feel like anything in the under 30 range is good.
Bronkers
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
Forgot about RTR options, will have another look, thanks!
Because I haven't seen good math/writeup dismissing the impact of a few pounds of rotational weight for fuel economy or acceleration/stopping.
If it's $1,500 to drop 10lbs/wheel (vs squatch @ 35lbs) I'd consider spending another $1,000 to drop another 5lbs/wheel(ie if the Titans were positive offset)
BUT...if it's a waste of money maybe I should change title and question of this post...
Lèòn
Jersey
Isnt Motegi Trailite’s 24lbs?
Moto26
Tucson AZ
This one is a little over 6 lbs… But you might need an adapter to put it on your Bronco… 😛
Ford Bronco Lightest 17" wheels *with positive offset*? 82A296FB-F732-4C6A-AD97-5E2F4DFE602C
Ford Bronco Lightest 17" wheels *with positive offset*? 7327B41F-4040-4B5B-ADF7-B40746A09E25
Bronkers
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
My Motegi Trailites are about a pound less than the 703s and are fairly inexpensive. +18 for the 17"
Missed that too...
+18 might be it!
And the price!
Thanks!
SuperDave150
Lubbock, TX
Ford F-150, Ford Edge
Ditto
I’d like to hear what people find.
Weight is weight and it always hurts performance. Plus it is more fun to change a flat when it weighs less. 😉
Tricky Dick
Dick
PNW
www.TD-Distributing.com
TNcoupe
Decatur,TN
2022 Badlands, 2023 BD, 1969 F100, 1955 T Bird
I might be a little biased but I think they look great too.
Any rubbing with the 35s on the +18?? I'm looking at trail dedicated wheels and 315 KM3s for my non Sasquatch Badlands 2dr.
Tricky Dick
Dick
PNW
None at all.
huey
kevin
Ontario & Kentucky
yeah those are the ones im looking at as well!
huey
kevin
Ontario & Kentucky
None at all.
curious if i should go 18 or stick with 17. going 18 I could have a slightly shorter sidewall which may subtly help on road cornering. what else to consider between 17 or 18
Bronkers
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
Excellent pic. I love golds/bronzes with all the blues (azure gray...) but I decided to retire it out of respect to my cg base (R.I.P.)
Blue on black from factory works (sans beauty rings) so I may not do anything for awhile but that motegi price is right
Tricky Dick
Dick
PNW
I'm not sure it will make much of a difference either way. 18s have a great tire selection as well.
They have a grey finish available too.
